Nas.CloudBusinessPortal
I'm posting a log... strange... not taking an chances, so i wiped the router clean, and starting over with new.
Any suggestions as to what is going on here? Asus router RT-AX88U with 3004.388.8.2
Too much information on the network to chance anything.
Sep 10 03:42:20 dnsmasq-dhcp[4382]: DHCPINFORM(br0) 192.168.1.254 00:0b:82:ee:fa:a1
Sep 10 03:42:20 dnsmasq-dhcp[4382]: DHCPACK(br0) 192.168.1.254 00:0b:82:ee:fa:a1 GrandStream
Sep 10 03:42:30 kernel: eth0 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link DOWN.
Sep 10 03:42:30 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Sep 10 03:42:30 kernel: Mcast: new client info: group_addr<239.255.102.18> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029f99000> wlinfo<0000> client_type<0> MAC<4c:72:b9:d4:fd:d0> rtp_seq_chk<0>
Sep 10 03:42:30 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Sep 10 03:42:30 kernel: Mcast: new client: matches with: mcast_group<0> client_id<1>
Sep 10 03:42:30 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Sep 10 03:42:30 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Sep 10 03:42:30 kernel: is_ssm 0 grp 239.255.102.18 src 0.0.0.0
Sep 10 03:42:30 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Sep 10 03:42:30 kernel: ***Client List***
Sep 10 03:42:30 kernel: to_accel_dev eth5 wl info 0x0 clientmac 68:14:01:44:fa:2f
Sep 10 03:42:30 kernel: ***Rx Info list***
Sep 10 03:42:30 kernel: rxinfo blog_p 0xffffffc029e9c540
Sep 10 03:42:30 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Sep 10 03:42:31 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Sep 10 03:42:31 kernel: Mcast: new client info: group_addr<239.255.255.253> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029f99000> wlinfo<0000> client_type<0> MAC<68:14:01:44:d2:81> rtp_seq_chk<0>
Sep 10 03:42:31 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Sep 10 03:42:31 kernel: Mcast: new client: matches with: mcast_group<1> client_id<1>
Sep 10 03:42:31 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Sep 10 03:42:31 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Sep 10 03:42:31 kernel: is_ssm 0 grp 239.255.255.253 src 0.0.0.0
Sep 10 03:42:31 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Sep 10 03:42:31 kernel: ***Client List***
Sep 10 03:42:31 kernel: to_accel_dev eth5 wl info 0x0 clientmac 4c:72:b9:d4:fd:d0
Sep 10 03:42:31 kernel: ***Rx Info list***
Sep 10 03:42:31 kernel: rxinfo blog_p 0xffffffc029e7aa80
Sep 10 03:42:31 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Sep 10 03:42:33 WAN(0)_Connection: WAN(0) link down.
Sep 10 03:43:20 dnsmasq-dhcp[4382]: DHCPINFORM(br0) 192.168.1.254 00:0b:82:ee:fa:a1
Sep 10 03:43:20 dnsmasq-dhcp[4382]: DHCPACK(br0) 192.168.1.254 00:0b:82:ee:fa:a1 GrandStream
Sep 10 03:43:25 kernel: eth0 (Int switch port: 6) (Logical Port: 6) (phyId: 13) Link Up at 2500 mbps full duplex
Sep 10 03:43:25 kernel: ^[[0;33;41mFCACHE ERROR: fc_config_mcast_group: Mcast: client has already JOINed the mcast group (duplicate JOIN)^[[0m
Sep 10 03:43:25 kernel: Mcast: new client info: group_addr<239.255.255.251> src_addr<0.0.0.0> is_ssm<0> tx_dev_p<ffffffc029f99000> wlinfo<0000> client_type<0> MAC<9c:8e:cd:1d:de:23> rtp_seq_chk<0>
Sep 10 03:43:25 kernel: rtp_seq_chk<0> mcast_excl_udp_port<0>
Sep 10 03:43:25 kernel: Mcast: new client: matches with: mcast_group<2> client_id<1>
Sep 10 03:43:25 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_clientinfo_node_add,843: blog_activate failure^[[0m
Sep 10 03:43:25 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_fc_flow_add,924: Error adding client info node^[[0m
Sep 10 03:43:25 kernel: is_ssm 0 grp 239.255.255.251 src 0.0.0.0
Sep 10 03:43:25 kernel: mcast_exclude_udp_port 0x0 rtp seq check 0
Sep 10 03:43:25 kernel: ***Client List***
Sep 10 03:43:25 kernel: to_accel_dev eth5 wl info 0x0 clientmac 9c:8e:cd:24:93:4a
Sep 10 03:43:25 kernel: ***Rx Info list***
Sep 10 03:43:25 kernel: rxinfo blog_p 0xffffffc029e78a80
Sep 10 03:43:25 kernel: ^[[0;33;41m[ERROR mcast] bcm_mcast_blogrule_vlan_process,319: Unable to create flow, continue^[[0m
Sep 10 03:43:25 WAN(0)_Connection: WAN(0) link up.
Sep 10 03:43:25 rc_service: wanduck 1481:notify_rc restart_wan_if 0
