Strange log entries since installing latest firmware
JTnola
Strange log entries since updating to the latest firmware
Also have had my first stability issues in ages (which is what led me to look at the logs in the first place) also, there are a lot of inbound connections blocked (while connected through the router vpn client) showing up on the logs, but so long as they are getting blocked, everything’s cool right? Aka, it’s per se a sign of something bad happening?)
any thoughts?
Y’all are great.
Aug 24 06:20:10 kernel: CPU: 1 PID: 6287 Comm: dcd Tainted: P O 4.1.27 #2
Aug 24 06:20:10 kernel: Hardware name: Broadcom-v8A (DT)
Aug 24 06:20:10 kernel: task: ffffffc0146c1440 ti: ffffffc010b90000 task.ti: ffffffc010b90000
Aug 24 06:20:10 kernel: PC is at 0xf740af44
Aug 24 06:20:10 kernel: LR is at 0x1dce0
Aug 24 06:20:10 kernel: pc : [<00000000f740af44>] lr : [<000000000001dce0>] pstate: 600b0010
Aug 24 06:20:10 kernel: sp : 00000000ffe51bf8
Aug 24 06:20:10 kernel: x12: 00000000000a2050
Aug 24 06:20:10 kernel: x11: 00000000f66ff024 x10: 00000000000a23c4
Aug 24 06:20:10 kernel: x9 : 00000000f66ff734 x8 : 00000000000a287c
Aug 24 06:20:10 kernel: x7 : 00000000f66ff76c x6 : 00000000000a2876
Aug 24 06:20:10 kernel: x5 : 0000000000000000 x4 : 00000000f66ff718
Aug 24 06:20:10 kernel: x3 : 0000000000000000 x2 : 00000000ffe51bd4
Aug 24 06:20:10 kernel: x1 : 000000000007d72e x0 : 0000000000000000
Aug 24 06:27:58 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:28:02 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
Aug 24 06:28:05 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:28:08 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 24 06:31:35 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:31:37 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
Aug 24 06:31:41 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:31:44 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 24 06:43:24 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:43:26 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
Aug 24 06:43:53 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:43:56 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 24 06:44:23 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:44:25 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
Aug 24 06:44:29 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 24 06:44:31 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 24 06:45:24 kernel: pgd = ffffffc0154a7000
Aug 24 06:45:24 kernel: [00000000] *pgd=00000000113ec003, *pud=00000000113ec003, *pmd=00000000049b5003, *pte=0000000000000000
… and these repeat over and over again
The dcd messages have been reported hundreds of times.
Other than that it looks like you might have a faulty LAN connection or cable. Or that device is in sleep mode.
