Suricata Suricata - IDS on AsusWRT Merlin
tha
Step 2 - inside your suricata yaml file (/opt/etc/suricata/suricata.yaml)
Step 3 - refer to syslog-ng instructions. copy the respective suricata files from *.share for both logrotate and suricata to their respective /opt/etc/logrotate.d and syslog-ng.d. Make sure the perms are root R/W (0600). Reload Scribe (syslog-ng (which restarts logrotate)).
thanks @ttgapers I will try to get this working today
tha
Finally found time to experiment with Suricata.
Seems my test suggestion was wrong:
In that rule I see "GPL ATTACK_RESPONSE id check returned root"
How can I test instead?
I had taken the test as soon as I released this post.
@rgnldo check my github...tried to Inbox you.
Nice! Very good. ;)
Well, It is necessary to reorganize the script.
The script must find the WAN interface and the router's IP CIDR insert in the file suricata.yaml
Only requirement: disable AiProtection
Remove the HND and QOS router requirement. Other users have tested it on other non-HND and QOS routers successfully.
There are situations where AiProtection is disabled in the GUI, not in NVRAM, preventing installation.
To resolve to apply this solution:
nvram set TM_EULA=0
nvram commit
service start_reboot
I organized a rule that detects that simulates a ping attack
Can you please post instructions on how to do that, so that others can perform this test as well?
Get
curl -o /opt/var/lib/suricata/rules/test.rules https://raw.githubusercontent.com/rgnldo/knot-resolver-suricata/master/files/test.rules
Edit and insert on suricata.yaml file, on rules
On network lan, with terminal macOS, Linux or Windows, run ping on IP router.
check /opt/var/log/suricata/fast.log
Thank you for providing the rules and instructions!
Unfortunately my fast.log remains empty. Will check later what's wrong with my setup.
@ttgapers I copied your syslog setup, but I don't see any alerts appearing in either fast.log or suricata.log; where do you get those alerts?
What's the output of:
suricata -T
> suricata -T
2/7/2020 -- 16:50:54 - <Info> - Running suricata under test mode
2/7/2020 -- 16:50:54 - <Info> - Configuration node 'defrag' redefined.
2/7/2020 -- 16:50:54 - <Warning> - [ERRCODE: SC_ERR_INVALID_ARGUMENT(13)] - Invalid syslog facility: "off", now using "local0" as syslog facility
That last line does not look good, does it?
Also surprised about the "defrag" one, which is from the default config.
Should I have done more than setting HOME_NET ("[192.168.0.0/16]"), interface (eth0), IP_DNS (192.168.1.1) in this file?
> suricata -T
Is that the whole output? It should look similar to this:
2/7/2020 -- 10:45:31 - <Info> - Running suricata under test mode
2/7/2020 -- 10:45:31 - <Info> - Configuration node 'defrag' redefined.
Warning: Output_interface not supplied by user.  Falling back on default_output_interface "Console"
2/7/2020 -- 10:45:31 - <Notice> - This is Suricata version 4.1.8 RELEASE
2/7/2020 -- 10:45:31 - <Info> - CPUs/cores online: 4
2/7/2020 -- 10:45:31 - <Info> - fast output device (regular) initialized: fast.log
2/7/2020 -- 10:45:31 - <Info> - stats output device (regular) initialized: stats.log
2/7/2020 -- 10:45:31 - <Info> - 17 rule files processed. 2333 rules successfully loaded, 0 rules failed
2/7/2020 -- 10:45:31 - <Info> - Threshold config parsed: 0 rule(s) found
2/7/2020 -- 10:45:31 - <Info> - 2333 signatures processed. 205 are IP-only rules, 443 are inspecting packet payload, 1764 inspect application layer, 0 are decoder event only
2/7/2020 -- 10:45:33 - <Notice> - Configuration provided was successfully loaded. Exiting.
2/7/2020 -- 10:45:33 - <Info> - cleaning up signature grouping structure... complete
The warning is normal, just tells you that the output is on the console screen and not a file.
Those 3 lines were all for the -T option on the command line.
In the log for a process start I do see more:
Jul  2 21:26:10 ac86u S82suricata: Starting Suricata IDS/IPS /opt/etc/init.d/S82suricata
Jul  2 21:26:10 ac86u suricata: 2/7/2020 -- 21:26:10 - <Notice> - This is Suricata version 4.1.8 RELEASE
Jul  2 21:26:10 ac86u suricata: 2/7/2020 -- 21:26:10 - <Info> - CPUs/cores online: 2
Jul  2 21:26:10 ac86u suricata: 2/7/2020 -- 21:26:10 - <Info> - Found an MTU of 1500 for 'eth0'
Jul  2 21:26:10 ac86u suricata: 2/7/2020 -- 21:26:10 - <Info> - fast output device (regular) initialized: fast.log
Jul  2 21:26:10 ac86u suricata[10412]: 2/7/2020 -- 21:26:10 - <Info> - Syslog output initialized
Jul  2 21:26:10 ac86u suricata[10412]: 2/7/2020 -- 21:26:10 - <Warning> - [ERRCODE: SC_WARN_NO_STATS_LOGGERS(261)] - stats are enabled but no loggers are active
Jul  2 21:26:10 ac86u suricata[10412]: 2/7/2020 -- 21:26:10 - <Info> - 18 rule files processed. 2332 rules successfully loaded, 0 rules failed
Jul  2 21:26:10 ac86u suricata[10412]: 2/7/2020 -- 21:26:10 - <Info> - Threshold config parsed: 0 rule(s) found
Jul  2 21:26:10 ac86u suricata[10412]: 2/7/2020 -- 21:26:10 - <Info> - 2332 signatures processed. 206 are IP-only rules, 443 are inspecting packet payload, 1762 inspect application layer, 0 are decoder event only
Jul  2 21:26:12 ac86u suricata[10412]: 2/7/2020 -- 21:26:12 - <Info> - Going to use 2 thread(s)
Jul  2 21:26:12 ac86u suricata[10412]: 2/7/2020 -- 21:26:12 - <Notice> - all 2 packet processing threads, 2 management threads initialized, engine started.
Jul  2 21:26:13 ac86u suricata[10412]: 2/7/2020 -- 21:26:13 - <Info> - All AFP capture threads are running.
I don't understand the line about stats either, since that's set to "no" (twice) in my config.
Looks like all is running. Regarding the log warrning see this post.
It will take a while but eventually you'll see some entries in the fast.log
But the test suggested by @rgnldo is a simple ping.
SkyNet does not block that?
Yes. Corresponds to the rule alert
alert icmp any any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
alert tcp any any -> $HOME_NET 23 (msg:"TELNET connection attempt"; sid:1000003; rev:1;)
Working
suricata -T
2/7/2020 -- 19:00:54 - <Info> - Running suricata under test mode
2/7/2020 -- 19:00:54 - <Info> - Configuration node 'defrag' redefined.
2/7/2020 -- 19:00:54 - <Notice> - This is Suricata version 4.1.8 RELEASE
2/7/2020 -- 19:00:54 - <Info> - CPUs/cores online: 2
2/7/2020 -- 19:00:54 - <Info> - fast output device (regular) initialized: fast.log
2/7/2020 -- 19:00:54 - <Info> - http-log output device (regular) initialized: http.log
2/7/2020 -- 19:00:54 - <Info> - stats output device (regular) initialized: stats.log
2/7/2020 -- 19:00:54 - <Info> - eve-log output device (regular) initialized: eve.json
2/7/2020 -- 19:00:54 - <Info> - 17 rule files processed. 2330 rules successfully loaded, 0 rules failed
2/7/2020 -- 19:00:54 - <Info> - Threshold config parsed: 0 rule(s) found
2/7/2020 -- 19:00:54 - <Info> - 2330 signatures processed. 204 are IP-only rules, 443 are inspecting packet payload, 1762 inspect application layer, 0 are decoder event only
2/7/2020 -- 19:00:56 - <Notice> - Configuration provided was successfully loaded. Exiting.
2/7/2020 -- 19:00:56 - <Info> - cleaning up signature grouping structure... complete
The suricata -T command is used to check the output if there are any errors.
