Excellent contribution.
I am trying to port the Oinkmaster, rule Management for Suricata. I'm counting on you.
Any progress? This would be a big plus.
Not really, but I would reboot it anyway to make sure it's all running again once your router restarts.Quick (probably ridiculous) question - do I need to reboot my router to make suricata run after install?
I'm brain dead. It's Friday...
/opt/etc/init.d/S82suricata stop
/opt/etc/init.d/S82suricata start
> suricata -c /opt/etc/suricata/suricata.yaml -T
3/7/2020 -- 21:43:47 - <Info> - Running suricata under test mode
3/7/2020 -- 21:43:47 - <Info> - Configuration node 'defrag' redefined.
Warning: Output_interface not supplied by user. Falling back on default_output_interface "Console"
3/7/2020 -- 21:43:47 - <Notice> - This is Suricata version 4.1.8 RELEASE
3/7/2020 -- 21:43:47 - <Info> - CPUs/cores online: 2
3/7/2020 -- 21:43:47 - <Info> - fast output device (regular) initialized: fast.log
3/7/2020 -- 21:43:47 - <Info> - stats output device (regular) initialized: stats.log
3/7/2020 -- 21:43:47 - <Info> - 18 rule files processed. 2335 rules successfully loaded, 0 rules failed
3/7/2020 -- 21:43:47 - <Info> - Threshold config parsed: 0 rule(s) found
3/7/2020 -- 21:43:47 - <Info> - 2335 signatures processed. 207 are IP-only rules, 443 are inspecting packet payload, 1764 inspect application layer, 0 are decoder event only
3/7/2020 -- 21:43:49 - <Notice> - Configuration provided was successfully loaded. Exiting.
3/7/2020 -- 21:43:49 - <Info> - cleaning up signature grouping structure... complete
alert icmp any any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
alert tcp any any -> $HOME_NET 23 (msg:"TELNET connection attempt"; sid:1000003; rev:1;)
If you want to stop and start Suricata you can use the following commands:
Code:/opt/etc/init.d/S82suricata stop /opt/etc/init.d/S82suricata start
I have Skynet, diversion, Suricata and cake all working together on my system and it seems to be working well.Alrighty, thanks!
I've only had it running on my ac86 for a little while, so I've yet to see if there are any problems/issues I need to sort out between cake-qos and suricata and Diversion, but right now things seem smooth. I had to wrestle with SkyNet, but this install was effortless, simply by following the steps in post #1 here...except for this: it's services-start rather than services.start on my system, and /opt paths didn't seem to be recognized, so I had to cd /opt to find the correct path to use.
The real test will be this evening as streaming activities begin in earnest.
I had similar issues as you with the installation instructions but it seemed to work using services.start. Is this an issue? do I need to change my install to use services-start?
Yep I'm quite sure it is all working. fast.log showing a few 'hits' but literally one every 2 days or so. I have scribe logging setup and see Suricata updating and restarting every day at 3am based on the cron job.You’re sure suricata is working? Until you’re 100% about that...
And don’t go by me/my experience: it could very well be me that’s wrong.
What is the best way to whitelist sites?
with HW acceleration enabled (default when not using qos), my top speed went from 550Mbps to 500Mbps, when i enabled suricata. this is on a ax88.Before i dip my toes in again with suricata, what kind of throughput are you guys getting? These routers are pretty limited in both cpu and memory. In my experience i had to run suricata on on i5/i7 with at least 16gb of ram to perform well. I even built a vm to route all my traffic through before i decided to just accept skynet and aiprotection.
For a moment I thought I found out why I don't get alerts (on eth0) when trying to ping my router...
But unfortunately still no change after changing this setting to "Yes"![]()
Yes, but I was directly ping-ing the IP.(oh, this is part 2 of 2. another post before)
do you have DDNS active?
anyone? other than the occasional NTP DDoS?for the folks running suricata, what entries have you found on fast.log, after running it for a while?
thanks
Welcome To SNBForums
