that only suggests the other two where prob faulty , as the ea9500 is pretty much as good as the best routers tested on 2.4 gig
the ea6700 we have little info on so cant say if it was crud
again though we have well past the so called extra coverage capability of any claims as with eirp reached the manufactures are not allowed to transmit above that level and can pull a rabbit out of a hat and produce extra coverage with any single transmission routers on ether band
So you mean basically the tests and rankings at SNB are useless then (apart from the leakage)?
