Viktor Jaep
Part of the Furniture
You only get a free sample... we're NOT giving away free product!! LOLSoftware that comes with it's own shampoo.
Hi and welcome to the forums.I have three routers in my home network, TP Link AX 55 connected to cable modem and internet with an USB drive 1, TP Link AX23 connected as a mesh node of TP Link AX 55, Asus AC87U
Wow, that's pretty crazy... what are your thoughts on this FAQ? Are you seeing any issues?
Can I use headscale and tailscale on the same machine?¶
Running headscale on a machine that is also in the tailnet can cause problems with subnet routers, traffic relay nodes, and MagicDNS. It might work, but it is not supported.
TAILMON v1.0.19 properly upgraded Tailscale version 1.68.1 to 1.68.2Indeed. Let’s wait for 1.0.17 and the next Tailscale update.
echo $SSH_CLIENT
Oh, that’s probably because the router is (configured as) a Tailscale subnet router?Why does the router report a Tailscale address, but the Pi a local address? (And not of the MBA, but of the router?)
Glad to be of help! LOLOh, that’s probably because the router is (configured as) a Tailscale subnet router?
Subnet routers · Tailscale Docs
Use subnet routers to give devices outside your local network access to services within specific subnets. Extend your private network with Tailscale.tailscale.com
The great advantage is that all the devices connected to your subnet router will effectively be on your Tailscale network (and not only your mac mini and synology). I use it to remotely access my firestick, my modem router, my WiFi access points, my security camera my TV tuner and alll other clients that cannot have Tailscale installed on them or do not have cloud access otherwise.This is maybe a dumb question but is there any advantage for me to run TailMon on my Router, if I already have a Mac mini and a synology running Tailscale Subnet? all Im seeing for Me is downsides of higher CPU load on my router, another device to make sure is updated, and potential crashes that could take my router down, and therefore most of my Tailscale network. I certainly see in some instances where this would be perfect, but am I missing something?
I think the OP, who has asked an excellent question, already has his Synology device set up as a subnet router, so AFAIK, that device could act as the means to access other devices (and to bypass CGNAT). This is what I did in my first foray into Tailscale (TS), setting up an RPi. It runs Tailscale natively, so ostensibly fewer performance issues.The great advantage is that all the devices connected to your subnet router will effectively be on your Tailscale network (and not only your mac mini and synology). I use it to remotely access my firestick, my modem router, my WiFi access points, my security camera my TV tuner and alll other clients that cannot have Tailscale installed on them or do not have cloud access otherwise.
I would say, it would probably also add for some redundancy... if the synology went down for some reason, being able to access other devices through your router would be the way to go, or to try to remotely troubleshoot the synology.I think the OP, who has asked an excellent question, already has his Synology device set up as a subnet router, so AFAIK, that device could act as the means to access other devices (and to bypass CGNAT)? This is what I did in my first foray into Tailscale (TS), setting up an RPi. It runs Tailscale natively, so ostensibly fewer performance issues.
You can also designate the Synology as an exit node.
For me putting it on the Asus Router was for reasons of simplicity, an all in one device (that does all the routing) and for those with TS on a travel router (like my GLiNET Beryl AX), absolutely it makes sense; but ASUS does not really make travel routers.
So as I said, it’s actually a good question, that was asked on a Reddit post some time ago. I am no expert but do not believe any of the answers there nail down definitely what advantages it has. I am hoping @ColinTaylor or @Viktor Jaep can throw some light on it.
I have used Tailscale SSH and the Taildrop features of Tailscale and they are pretty cool directly on the Router.
k.
I believe Synology has it's own OS based on Linux, so I’m guessing it uses a similar approach to an RPi or other Linux device.Sorry missed the Synology as a subnet. Not wishing to stray off here but how can a NAS drive act as a subnet router (when it is in fact not a router)? Your learn something new everyday.
Slightly off-topic:TAILMON v1.0.19 properly upgraded Tailscale version 1.68.1 to 1.68.2![]()
An update to my issue. I gave up since our last conversation and I had a try again today. I had a regular wireguard server setting on my local router and client setting on the remote router. I tried this time and deactivated both and now Tailscale is working as it should be.I switched both to kernel mode to no avail. I also deactivated the exit node (I only use it on demand, each network should use its own local internet and I only want the devices to have interconnectivity). Could it be that tailmon is blocking me from changing the setting with tailscale set command? When I tried to deactivate exit node with set --advertise-exit-node=false didn’t change the connection command line in tailmon until I set the option for exit node inside tailmon to no.
Correct, I already have TS running a subnet and exit node on both Synology NAS and Mac mini, so redundancy also covered, as are all my cameras and devices I need to access from within the LAN. which is why I was wondering, other than adding additional work load to my router CPU, is there any Killer app to this that Im missing. Doesnt sound like it. I understand for people without spare desktops or NAS, allowing a Subnet /access to the LAN from the router is a huge win.I think the OP, who has asked an excellent question, already has his Synology device set up as a subnet router, so AFAIK, that device could act as the means to access other devices (and to bypass CGNAT). This is what I did in my first foray into Tailscale (TS), setting up an RPi. It runs Tailscale natively, so ostensibly fewer performance issues.
k.
Welcome To SNBForums
