Solved Tencent download acceleration?
DJones
This might have been fixed I’ve yet to go to the beta as I’ve just been waiting for the release. This is probably a remanent from the GPL meant for the Chinese market? Canadian router so makes sense that’s not included.
This ia an issue with the webui addon that you use which blindly builds menus without checking if the feature is enabled or not on the router.
Tencent Accelerator is indeed only enabled on routers having the China region code, and only on some specific models.
Probably scmerlin is the cause. That’s good to know.
