MDM
I get it, but I do not have a external drive attached to the USB, but IPV6 is new for me here...Window PC's already run WSD. The question is can your PC discover the router using WSD instead of NetBIOS.
4 days and router share is available still.If I recall, the previous issue that was reported when I last attempted to update wsdd2 was that after a while wsd discovery would stop working. Please have a look after a few days to see if the router is still discovered.
I am hoping that a recent fix to wsdd2 would resolve this issue that had prevented me from updating it until now.
You also need to check that the discovery method is still WSD and not NetBIOS.4 days and router share is available still.
I don't seems to see how to add discovery method column in windows 11(OS Build 22631.3527) explorer? My router share is set for SMBv2 only.You also need to check that the discovery method is still WSD and not NetBIOS.
See RMerlin's post (#88) one page back. It is explained there.I don't seems to see how to add discovery method column in windows 11(OS Build 22631.3527) explorer? My router share is set for SMB2 only.
NVM found it, it is using WSD discovery. I have to sort it to group by discovery method.I don't seems to see how to add discovery method column in windows 11(OS Build 22631.3527) explorer? My router share is set for SMB2 only.
Edit: I found the selection to add discovery method but in this windows it doesn't show even if chosen. Any other way I can check?
Look at the lines before that. Something actively caused the WireGuard client to be stopped, otherwise there wouldn't be a log entry about it.388.7 beta,ax86u
log show:
Apr 26 09:19:00 lldpd[1713]: removal request for address of 11.6.0.2%32, but no knowledge of it
Apr 26 09:19:00 WireGuard: Stopping client 1.
388.6.2 is no problem.
OT: Did you deactivate NetBIOS at the W10 PC?Interesting, my W10 PC see W11 LapTop as WSD, but W11 see W10 as NetBIOS..?![]()
NO!OT: Did you deactivate NetBIOS at the W10 PC?
Just because I'm curious, what about disabling netBIOS? Just for testing purposes of course.
Apr 26 12:46:52 dropbear[1946]: Error forking: Cannot allocate memory
Apr 26 12:46:55 dropbear[1946]: Error forking: Cannot allocate memory
Apr 26 12:48:04 dnsmasq-dhcp[1762]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Apr 26 12:48:13 kernel: wl0: random key value: 196865FF29EDC1140C1E03A043A0341B87CF5330C7D20A6A1DE906FDC06DF1A5
Apr 26 12:48:17 dnsmasq-dhcp[1762]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Apr 26 12:48:21 dnsmasq-dhcp[1762]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Apr 26 12:48:21 dnsmasq[1762]: script process exited with status 127
Apr 26 12:48:22 dnsmasq[1762]: failed to send packet: Network is unreachable
Apr 26 12:48:33 kernel: wl0: random key value: 4C6E8A3FC868DFBF2BA5034263183995CD0D95C74A06009C7C83B010DE8D8D67
Apr 26 12:48:53 kernel: wfd_registerdevice Successfully registered dev wds1.0.2 ifidx 3 wfd_idx 1
Apr 26 12:48:53 kernel: Register interface [wds1.0.2] MAC: 3c:7c:3f:e1:e4:14
Apr 26 12:48:53 kernel: netdev path : wds1.0.2.0 -> wds1.0.2
Apr 26 12:48:53 kernel: BCMVLAN : wds1.0.2 mode was set to RG
Apr 26 12:48:55 dropbear[1946]: Error forking: Cannot allocate memory
Apr 26 12:48:56 dnsmasq-dhcp[24629]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
Apr 26 12:48:59 dnsmasq-dhcp[24629]: failed to write /var/lib/misc/dnsmasq.leases: No space left on device (retry in 60 s)
admin@ax86u-office:/tmp/home/root# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
ubi:rootfs_ubifs 79592 71832 7760 90% /
devtmpfs 466864 0 466864 0% /dev
tmpfs 466980 220 466760 0% /var
tmpfs 466980 1436 465544 0% /tmp/mnt
ubi1:data 4584 72 4240 2% /data
/dev/mtdblock9 48128 3284 44844 7% /jffs
Welcome To SNBForums
