Unless you get really crazy with 8 stream designs, you are looking at a realistic max of 2.7Gbps raw wireless rate with a 4:4 160MHz design. With MU:MIMO, you lose effectively 1 stream, which actually bumps it down to roughly 2Gbps if you have a number of MU:MIMO 160MHz clients connected.
Figure in error correction overhead and the BEST you can possibly hope to achieve is around 1.7-1.8Gbps...which means that a pair of GbE ports in LAG actually more than handles the possible throughput that the router could see.
The only instance where LAG is unlikely to ever make sense is where you are encountering >4:4 stream routers or 3:3 or 4:4 clients that are also utilizing 160MHz (2:2 with 160MHz might also >1Gbps, but it is going to have to be a VERY good connection to be able to exceed that).
For a client device, I think those scenarios are going to be a lot more limited.
One other assumption here is that the router and any switches or other devices that are connected to it are not going to be able to split the TCP packets between interfaces, so each client is going to be stuck with no more than 1Gbps, just that multiple clients can be aggregate across the links, just like how LAG generally works now (as opposed to being able to do multichannel, which is much more a client sided thing as far as I know, and not a network device thing).
Anyway, 10GbE would of course be the ideal, but since I think we are a good 3-5 years (isn't everything?) away from that being even typical prosumer/high end enthusiast gear, I don't see router manufacturers (except enterprise) entertaining that. LAG on the other hand is solely a firmware feature and pretty danged easy to implement (granted you'll need devices that support LAG behind the router too, but again, not very expensive and easy to implement), both in the home and ESPECIALLY in any kind of business.
LAG could realistically be deployed now on all new routers and most home/business users could take advantage of that at either no cost, or possibly no more than a $60-200 additional cost (if not less on a per installation cost for multiple installations).
A final note is, this is all assuming very good connections for all clients. Since it probably isn't likely that you have 2, 3 or 4 clients all in the same room, all that have very high throughput capability (11ac 160Mhz or not), you might really be connecting a bunch of clients that are each only squeezing 20-40MiB/sec, even on an 8:8 router design as most are a room or two away, or line of sight, but a good distance, etc. So you are back to LAG being more than enough in a lot of cases.
