the one left behind
bogolisk
Hi
I have a RT-N16 running a version of Merlin and I've been really happy with it. Now Merlin no long support it, what would be a good firmware for it?
  • I don't use it for wireless, I have 3 AC APs. Radio is turned off, I use it as a wired router.
  • I need dnsmasq: static DHCP, mapping multiple MACs to 1 IP and ads-blocking.
  • I need ddns support (custom is ok, right now I'm using custom with afraid.org)
  • I need good QoS (MAC based) for VoiP.
  • I need secure NAT :)
  • I need good performance :)
  • Ability to turn-off wireless.
  • I need parental control
  • high performance vpn (l2tp/ipsec) would be very desirable.
  • working MSS clamping.
  • syslog
thank you.
Hi
  • syslog
thank you.
I had a RT-N16 running dd-wrt firmware as a router only (no wifi) for a long time. It actually came with dd-wrt on it from ASUS, I just updated it to the latest version. I was very happy with the performance and of course all the functionality that comes with dd-wrt. I can't vouch for wifi performance but if you just need router only then I'd highly recommend it.
