Time Machine runs out of space
herrdude
Hello!
I have set up Merlin on my ASUS AC56U. I really like it as it does everything I need to do. I have been lurking in these forums getting everything sorted out.
However, there is one thing I cannot get working. I can't even get the initial backup working. The time machine on the router just doesn't work for me. It gets to a certain point and errors out. Often it gives the message that there isn't enough space. The backup size is around 40GB going onto an empty 500GB drive. So space is not the issue. I have tried HDS+ with and without journaling. I have also tried FAT, ext3, and ext 4. I have tried backing up through the network cable and wifi. Also USB 2.0 and USB 3.0. No dice.
This is the log I got where things crap out:
Dec 26 20:32:18 Timemachine: daemon is started
Dec 26 20:32:42 afpd[987]: AFP3.3 Login by admin
Dec 26 20:32:42 cnid_dbd[988]: Couldn't open extension maping file /usr/etc/extmap.conf
Dec 26 20:32:42 cnid_dbd[988]: Couldn't load extension -> type/creator mappings file "/usr/etc/extmap.conf"
Dec 26 20:34:31 dnsmasq-dhcp[781]: DHCPREQUEST(br0) 192.168.1.153 18:3b:d2:b0:82:98
Dec 26 20:34:31 dnsmasq-dhcp[781]: DHCPACK(br0) 192.168.1.153 18:3b:d2:b0:82:98 android-f23c55caab6131de
Dec 26 20:39:32 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:14:42 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:14:43 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:14:44 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:14:44 kernel: sd 0:0:0:0: [sda] Unhandled error code
Dec 26 21:14:44 kernel: sd 0:0:0:0: [sda]  Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Dec 26 21:14:44 kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 20 41 7c 42 00 03 00 00
Dec 26 21:14:44 kernel: end_request: I/O error, dev sda, sector 541162562
Dec 26 21:18:31 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:18:32 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:18:33 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:18:33 kernel: sd 0:0:0:0: [sda] Unhandled error code
Dec 26 21:18:33 kernel: sd 0:0:0:0: [sda]  Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Dec 26 21:18:33 kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 20 35 47 82 00 03 c0 00
Dec 26 21:18:33 kernel: end_request: I/O error, dev sda, sector 540362626
Dec 26 21:18:34 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:18:35 kernel: usb 2-2: reset high speed USB device using ehci_hcd and address 2
Dec 26 21:18:36 afpd[987]: dsi_stream_read_file: Input/output error
Dec 26 21:18:36 afpd[987]: afp_read(4bb): ad_readfile: Input/output error
Dec 26 21:18:36 afpd[987]: afp_read(4bb): Input/output error
Dec 26 21:18:36 afpd[987]: AFP statistics: 13977088.03 KB read, 143645.31 KB written
Dec 26 21:18:36 kernel: sd 0:0:0:0: [sda] Unhandled error code
Dec 26 21:18:36 kernel: sd 0:0:0:0: [sda]  Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Dec 26 21:18:36 kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 20 35 47 82 00 00 80 00
Dec 26 21:18:36 kernel: end_request: I/O error, dev sda, sector 540362626
Dec 26 21:18:43 afpd[1018]: AFP3.3 Login by admin
Dec 26 21:18:43 afpd[1018]: afp_disconnect: trying primary reconnect
Dec 26 21:18:43 afpd[974]: Reconnect: no child[987]
Dec 26 21:18:48 afpd[1018]: afp_disconnect: primary reconnect failed
Dec 26 21:18:49 afpd[1018]: dsi_stream_read: len:0, unexpected EOF
Dec 26 21:18:49 afpd[1018]: afp_over_dsi: failed reconnect
Dec 26 21:18:49 afpd[1018]: AFP statistics: 0.55 KB read, 0.38 KB written
Dec 26 21:19:05 afpd[1019]: AFP3.3 Login by admin
Dec 26 21:19:05 afpd[1019]: afp_disconnect: trying primary reconnect
Dec 26 21:19:05 afpd[974]: Reconnect: no child[987]
Dec 26 21:19:10 afpd[1019]: afp_disconnect: primary reconnect failed
Dec 26 21:19:10 afpd[1019]: dsi_stream_read: len:0, unexpected EOF
Dec 26 21:19:10 afpd[1019]: afp_over_dsi: failed reconnect
Dec 26 21:19:10 afpd[1019]: AFP statistics: 0.55 KB read, 0.38 KB written
Need a swap space ?
Your hard disk seem unstable. I see a lot of USB-related errors in your log. Make sure that disk uses an external power source, as USB-powered disks are rarely reliable.
It is in a powered USB 3 enclosure.
I will try a different hard-drive and report back.
PS How do I create a swap drive?
Have you tried with a different hard-drive ?
Yes. It wasn't the disk.
I narrowed it down to either the hard drive case or the usb extension cable.
I changed both and my macbook managed to do a complete backup (through the network cable). Now, I am seeing if it will work through wifi.
PS I was wondering if the RT-AC56 can run ad-block software...
SOLVED!
As it turns out, you cannot use a USB 2.0 extension cable with a USB 3.0 enclosure.
DOH!
Everything is working as expected.
Thanks.
For my own information, how did you manage to connect a usb2 male connector into a usb3 female connector ?
The male for USB 3.0 is the same as USB 2.0. I plugged the male for USB 3.0 into the female of the USB 2.0 extension.
Cheers!
