Time Parental filter can be bypassed by changing the IP address
MAC addresses are also easily changed or spoofed. These days most devices do it for you as a privacy feature.
You can prevent that by setting your MAC filter mode to "Accept." Then the MAC has to be present and accounted for before they can use the WiFi at all. Has the beneficial side effect of booting off Apple devices that use random MACs every time they connect.
well I tried to test this as you say and I tested on my own router and then it turned off wan so I could not remote control from my own router, I did not report that bug when I did not think about it
If you're setting that up from a WAN client you have to add that one before you hit save, otherwise you'll be locked out as you discovered.
okay then I have to do it later when I visit my sister because we live 3 hours apart and I do not have a car to be able to go back and forth
I can maybe help her if I remotely control her phone and go try to log in to the router about when and how when she is home so she can give me permission for her phone,
may wish you and you a good day reading this
well it seems that asus has fixed it with asus about being able to fix with mac filter when I tested on mine for safety and it went so I have fixed it now on my sister's router, I really hope it helps so he does not find another bypass
i tested mac filter and it shut down everyone's wifi with these settings on all mac addresses and have to disable it completely, it's probably a bug on the router anyway
It's supposed to shut down everyone's WiFi unless their MAC address is in the list.
yes talked to someone who works in broadband and this person said that you can not do anything about it but says that security holes will always be on the internet and I think this person did not want to answer my question and yes ask if you could turn to someone if sure about parental control but unfortunately no response was received
well I got an answer from asus and now I'm not as annoyed as I have waited a long time for an answer from them and got a little more answer and I think it's good than getting a standard answer, good night to you
if you want to use dns.yandex on Wan, you should only have one dns 77.88.8.7 if you want to stop pornography on the search engine without it being able to bypass images and video, it is good to use this and the other dns it has that are under on the same family filter only 77.88.8.7 works and the other with dns 77.88.8.3 should be skipped or not used as it does not work as it should
dns.yandex on Lan, it is not possible to log in normally on the asus routers website
otherwise I recommend dns.yandex to use as standard if you have small children at home, it has been solved with a while that parents control works with of dns filter in Lan
