Time to replace my RT-AC88U
This recommendation hasn't changed for many months now.
The GT-AX6000, the RT-AX88U Pro, and as a last resort (very unbalanced hardware that is hard to recommend today, even with your current ISP speeds, now), the RT-AX86U Pro.
See which models are available in your area, and wait for a good sale if you can.
I'd love to understand the issues with the AX86-U Pro; what leads to the hardware being considered unbalanced.
Just someone’s opinion based on the fact the router has single 2.5GbE port. Most folks don’t have or need >Gigabit ISP plan.
Thank you for your quick answers.
The bad thing with Tomato is the problem that it doesn't support LAN ports 5-8.
That was my point why I bought this router, to get 8 LAN ports without using another switch which always disturbs my home network.
a switch is cheap and will last many years . I have read many posts where the ports on tha router are not reliable
2.5 gb port is still useful for transfers , computer to NAS or other connected devices
Single 2.5GbE LAN port won't be very useful. For faster LAN transfers switch is cheaper. Paying extra for unused features and planning for the future on a disposable type consumer device is a wrong strategy. This device will be End-of-Life in number of years and has to be replaced again.
Don't expose any services to Internet and you'll be fine
I don't use any DMZ and Port Forwarding, but I rely on DDNS and OpenVPN. I also use AiProtection.
So if I really want to be on the safe side I could use like the Netgear GS308 switch on port 4 for example if I move to Fresh Tomato ?!
Or I put enormous effort and build my own router with OpenSense on a MiniPC and use my "unused" TP-Link Deco as Wifi-AP..
Supports VLANs, Access Point mode and Repeater Mode - all you need to recreate what Asus marketing calls AiMesh.
thank you Mesh is just marketing or newspeak for something that has always been there
A single 2.5 gbe port is useful for interfacing the wifi router wireless traffic to a multi-gig switch.
Speaking of EOL, Netgear EOLed my MS-510TX multigig switch within 3 years of introduction. Gotta love Netgear for their short product lifetime cycle.
We are talking about RT-AX86U Pro and RT-AX88U Pro, remember? Dual-band models with one only higher speed radio on 5GHz band. In theory you are correct, perhaps for a multi-band or BE-class router. In reality for dual-band AX-class router very few devices can exceed Gigabit on Wi-Fi and special conditions have to be met - clear DFS for 160Mhz wide channels, device with 160MHz wide channel support, quiet Wi-Fi environment, shorter range.
I generally agree that saturating even a 1 gbps ethernet with wifi traffic from an AX88U Pro or AX86U Pro is unlikely, but I'll take whatever extra headroom I can get.
I moved to freshtomato-VPN version on the latest version and I like it.
But I still have the behaviour that Internet(WAN) behind my 5G Router in Bridge Mode and WAN on my AC88U over DHCP, regularly drops connection and only a Reboot helps to gain connection again.
In the log you see "daemon err stubby[24170] *FAILURE* no valid transports or upstreams available!". DDNS works fine, IPv6 is deactivated and I use DNSSEC with Stubby and "no resolve" or "strict order" doesn't change a thing with this connection drop.
In AsusWRT there was no option for wireguard and in freshtomato there is one. I have OpenVPN Server running and autostarted.
I managed for some seconds to get a wireguard connection but then I always get the message "unable to bring up wireguard interface wg0, retrying..." and "wireguard: wg0: Could not create IPv6 socket"
Cannot find any solution for both. When I want to config wg0 in the command section there is always message "no such file and directory" or "access denied".
I formated JFFS and when I save it it says "loaded". Cleared NVRAM many times but doesn't make a change either.
I'm not sure if this Thread describes my problem but when its the case then I really bought a total "sh......" Router.
With Wireguard could it be the problem that jfss is not working properly ?
I don't think SSH is necessary (which i deactivated) because OpenVPN is running with no prob and wireguard ran for few seconds..
sometimes it can be a handful plus if the router goes bad no Asus warranty , if router is EOL who cares go for it
It's possible to install the original firmware to claim warranty, but $100 for a new AX59U is not a big risk for me.
My AC88U has done over 10 years now. I see it is coming to the end of support so have been looking. So many more routers now to research!
