Time to replace my RT-AC88U
My current setup does include "several" IOT devices that I keep reading should be placed on a VLAN to isolate them from the internet.
Isolate your IoT devices from the Intranet (aka your local internal network - LAN) or from the Internet (aka the WAN)?
Generally for isolating IoT devices from the LAN/Intranet one can use the WiFi Guest Network feature of existing Asus routers to accomplish that task. For blocking Internet access that typically involves either using Parental Controls > Time Scheduling, or if using Asus-Merlin firmware using YazFi WiFi addon, or using scripting to block clients from accessing the Internet.
Currently the Guest Network Pro feature of the 3.0.0.6.102_x firmware on the AX Pro series and certain newer Asus routers is a mixed bag. Some features do not work as expected, or the features have quirks or issues. Use the forum search to find various other discussions on Guest Network Pro issues when trying to isolate WiFi guest clients from the Internet.
I currently have most of my IOT devices on the Guest Network on my AC3100, but still give Guest Network access to local intranet. Not sure if that "isolates" them from the internet or not. The AX88U-Pro has been out for a while. I just don't want to upgrade now and then discover 6 months (or a year) from now it too has reached Asus "end of life". Do you think the AX88U-Pro still has "gas in the tank"?
