tmpfs - resizable?
p_shep
The /tmp directory is made up of the system RAM and is sized at 118Mb... is it possible to adjust this?
I'm running a program which uses a lot of ram, and if making this smaller will free up system, it'll be helpful.
Thanks.
Thanks.
You can adjust the size of tmpfs via "mount -o remount ...", however I don't think it will help. For the memory used by tmpfs grows and shrinks to accommodate the files it contains, so your memory-hungry program will keep hungry even if your minimize tmpfs. See this link for more info.
https://www.kernel.org/doc/Documentation/filesystems/tmpfs.txt
But you may try, and please tell us what you found.
Ah, ok. that makes sense with the numbers I'm seeing.
Only 3% of the 118MB is being used, so if the tmpfs is resizing itself then there's no need to change it.
Thanks for the info.
