What is the voltage rating on the power supply?
Is it internationally rated? i.e. 100-240V?
Product Name: Ultimate Wireless N Gigabit Router
Model Number: TL-WR1043ND
- Wireless N speed up to 300Mbps
- 4 Gigabit Ethernet ports and 1 USB2.0 port
- 3T3R MIMO, SST, CCA technologies deliver greater coverage and higher speed
- Wireless Security encryption easily at a push of “QSS” button
- Built-in QoS, supports WDS Bridge
- Backward compatible with 802.11b and 802.11g devices
I just bought a TP-LINK WR1043ND. I am trying to use it to wirelessly bridge another Wirless n router (non TP-LINK) that doesn't support WDS but connects to my ADSL model. So far I haven't been able to get internet access through TP-LINK WR1043 and devices connected to TP-LINK router cannot see devices connected to the router I want to bridge. Is it possible for such configuration to work?
Thanks.
For those of you interested to see how I have setup TP-LINK TLWR1043ND go here
Assuming your data was moving only through the switch part of the product, and the switch indicates 1000BT connection in its lights, then the speed would be limited the data transfer software and methods. E.g., If windows shares, the size of the file matters - need one big file to get max speed. Speed of CPU on each end, and proper TCP/IP stack settings, etc. With lots of small files, you'll see low speeds due to file system overhead. Of course, the disk speeds can constrain too....but conection wire bandwidth only around 30 K KB/s = 240 Mb/s
but why the speed wire conect cannot get 1000 mb/s (gigabit)?
other hardware my pc are MSI X58 with nic gig, and other PC with TG3269.
i use cable with spec Cat 6.
/156uuu.jpg[/URL]
Welcome To SNBForums
