Traffic Analyzer - wrong data for a single client (5 bugs in one go)
Pila
Asus RT-AC56U fw 380-57.
Bug 1: Can not change a date format from USA to European style. I have set the timezone correctly and time is NTP from my server. Well, who cares about the Europe, there are not even ac European channels but only 4 US channels (while 2.4 channels are cotrect). And my modem is set to DE (EU/13) GERMANY (by default).
Bug 2: If I change a Date for display, no reason for automatic Client change to All clients. If I have selected one client, let it be - I want to see the traffic for that one client in several periods.
Bug 3-: Traffic Analyzer - wrong data shown for a single client
edited out. It was a resolution problem, error on my side.
bug 4: If I change "Show by" field, selected client will be displayed correctly, but the selection box for the clients will change to All cients (false).
bug 5. creating Guest Network (tried 2,4) garbles existing main network (changes SSID and pwd to one of Guest).
Two more bugs on this subject:
1. Trafic Analyzer - sometimes when called, comes up empty with no selection tabs (normally, tabs are: Ethernet, Wired, 2.4, 5) and no traffic is shown. This happens maybe once in every 5 to 10 times I want to see the traffic.
2. Trafic Analyzer - Statistic: Does not show Monthly view. Only capable of showing 31 days prior to the selected date. If I select Monthly view and select February, I must see only dates from 28 (or 29) days of february and not days from any other months. I must be able to see the traffic I made in the current month before it ended (I do not have flat rate Internet). Now, if I want to see my trafic in the Februarry, I must select the 2.3.2016. (this is EU date format) - select March 3 to see the February trafic?. Until the March actually arrives and I will never again be able to check the February trafic.
