[Beta] RT-AC87U/RT-AC3200 9.0.0.4_378_9481 Beta for checking bug in Traffic Analyzer -> Statistic
build 9366? that's the one I'm running now and still having this issue. The entire set of 9xxx builds have had this problem for me.
Much nices and smoother running build, but I'm still getting punted. I'm also noticing a lot of these errors when I reboot, could I have defective memory or something, or can they be ignored? running build 378.56_2 right now, or did I get the wrong build again?
Dec 10 16:58:14 kernel: Empty flash at 0x00124154 ends at 0x00124950
Dec 10 16:58:14 kernel: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00124950: 0xffff instead
Dec 10 16:58:14 kernel: Further such events for this erase block will not be printed
Dec 10 16:58:14 kernel: mtd->read(0x1b6a8 bytes from 0x124958) returned ECC error
Dec 10 16:58:14 kernel: Empty flash at 0x00124954 ends at 0x00125150
Hi Korbyn,
Yes, I redirect you to here, but I don't want you reply question here, you can send mail or have a conversation with me. Actually, what's your problem is about "httpd crash", I think it's due to networkmap or client list issue, it isn't time scheduling or AiProtection issue. Recently, we have anther R&D to modify networkmap. And please don't reply here, I will delete your reply here, I think I have noted very clearly in my top thread.
Thanks,
Vanic
Hi all guys,
Thanks for your support, testing, and suggestion here. The traffic analyzer issues should be fixed here in last one month, I will unstick this thread. If I need any help, I will create another one. Maybe there is another R&D who will post here to fix network map / client list / httpd crash issue. Let us fix all possible issue step by step. Recently, I find out there are a lot of people having question on AiProtection / Alert mail etc., I will post another announcement here to clarify questions.
Thanks,
Vanic
Thanks Vanic!
Unsticked the thread for you.
9366 firmware, the Taiwan version of the router transmit power 320mw, using the 128mw
Hello Vanic
Is in new official FW 9383 is added you all fixes from this thread ? Because in this new FW 9383 are still a few bugs which in your beta 9366 was resolved.
i not test this FW, becouse ASUSWRT say that new fw should be on new codebase 380. For me this fw is still beta.
But we dont know when code 380 will be available...? For AC68U is now in new code...
IMO when quantenna release new SDK
But ASUS WRT tell me that 9383 resolved problem battery drain. And driver in this FW is new.
this is not solution, Asus add only workaround
Hi all,
1. 378-9383 should be added all bugs fix from mine.
2. 380-xxx also be added.
Don't discuss about battery drain issue here, you will confuse other users to read this thread topic. Please make it clean, I have said several times. If you want to discuss other issues, please create another topic to do. that
Thanks,
Vanic
But in 9383 is still problem with colors. When select one color on back date and rhe go to today client name and data show in orher colors. But in your beta 9366 works ok.
As show bug in post #12 , #13, #14
i will test this today night, but in 9366 no problems with colors.
Ok wait also for your info. In 9366 i also have no problem.
In 9383 is next problem in TA. When i set back date and select button APPS, show ok. Then i select date TODAY and button APPS is still TURN ON, but data show name client (as button ROUTER) not show protocol(as button APPS)
Hi Piter,
I got what you mean, yes, it's a bug in GUI. It will postpone 2 or 3 weeks because the related R&D has a long vacation.
Thanks,
Vanic
Ok thanks. But problem with not change colors also is postpone ?
