Traffic stats
damianbl
I save the traffic stats on Asus RT N66U to custom location. I get the tomato_rstats_d850e6ae6c98.gz file.
How can I view the stats after unpacking the gz archive? It doesn't look like it is regular text file.
Thank you in advance.
You can't. This isn't a human readable format, it's intended for the router's own usage, to be processed and displayed on the webui.
Understand. Thank you for your answer.
Can I somehow get the traffic statistics (current rate would be sufficient) using the shell?
Not out-of-the-box, you would have to install additional software through Entware.
Best you could do is view the packet count on the network interfaces.
cat /proc/net/dev
I have Entware installed so I can install additional software. If you point me in the direction what software I need, I'd really appreciate it.
I can't remember what was the name of the shell-based tool that would provide network throughput statistic, you'll have to browse the list of available Entware packages.
@ryzhov_al might possibly remember?
