binarydad
I'm trying to figure out if the PCI NIC (made in 2003) is failing. Here are the symptoms:
1. Sometimes on large transfers TO this server, it will freeze the transfer. At that time, the entire network seems to come to a craaaawwwwwlllll and I can't connect to anything. Shutting down the machine immediately allows network activity to resume.
2. This morning, I wasn't able to even boot the machine. It froze up part-way into loading Windows, even under Safe mode with networking support. The only way to get it to boot was in regular Safe Mode. I moved the NIC to a different PCI slot and it SEEMED to be better, but just now I noticed the same issue. So it might not be the slot.
3. At one instance, I plugged a cable into the jack of the NIC and the machine rebooted.
4. Usually when it freezes in a transfer, I'll notice the NIC speed drop from 1Gbps to either 10 or 100mbps.
I'm mainly curious about #1. How can a faulty NIC pretty much kill the entire network? Will it damage my router and switch?
I realize NICs are between $10-$15, so I'll just get a new one, but I want to make sure it's not something else.
Thanks.
Thanks.
