Transmission and asuswrt merlin firmware problems (360.84)
erdemefe
Hi everyone,
First of all sorry for my bad English, English is not my mother language so i won't be tell clearly myself.
I installed asuswrt merlin (build 380.64) in my RT-AC68U and install transmission torrent client while fallowing this article https://github.com/RMerl/asuswrt-merlin/wiki/Installing-Transmission-through-Entware but i have a few problems about my system.
1) Sometimes SSH feature will disable itselfs on my web gui so i can't connect before open it on web gui.
2) i have static IP from my ISP so i don't need to DDNS. but when i try to connect my router from WAN, i will get a warning about other ip is connected. But i'm sure nobody is connected my router except my tried ip.
3) My JFFS scripts about port forwarding to router's ip address don't start at startup. I have to write commands after each reboot.
4) A 4TB USB HDD (NTFS) and a 500mb USB flash disk (EXT3) is connected into my router. HDD's name is sda1 and flash disk name is sdb5.
Entware and transmission are installed on flash disk but transmission download and inprogress paths are in USB HDD. Everything is working good before reboot.
When i reboot to router, flash disk will mount before acording to HDD and transmission service will work, but hdd is still won't mout. So torrents can't find to location to download path because HDD didn't mount yet. A few minutes later HDD also mount, but transmission won't to start to download before i pause and start again or click on the "verify location" button for each torrent file on transmission.
5) i use "Alternative Speed Limits" feature with "Schelduled Times" on transmission. i want that is my trafic is stop completely except scheldule times so i write 0kB/s alternative upload and download limits, but transmission doesn't accept this. i will see older limits, when i open the settings window.
6) Sometimes Transmission service will goes down itselfs. i didn't understand reason.
If you use Transmission or any other memory hungry application on your router with limited RAM, you need to have a swap file or partition enabled. Do you have it?
Some of you issues might go away if you have a swap file installed... :rolleyes:
İ have never tried. i will try the swap file or partition
GM 5 Plus d cihazımdan Tapatalk kullanılarak gönderildi
How can i start all torrents if transmission couldn't find download path? or how can i start transmission service after the USB HDD mount?
i didn't to start service after mount. My linux knowledge is so bad. But stopping service issue is good now for swap file.
