[TUTORIAL]CHEROKEE web server through optware
From the log you sent, gdbm is missing...
ipkg install gdbm
Does not work.
The output is:
admin@RT-AC68U-93A8:/tmp/home/root# ipkg install gdbm
Installing gdbm (1.8.3-4) to /opt/...
Downloading http://nw-dlcdnet.asus.com/asusware/arm/stable/gdbm_1.8.3-4_arm.ipk
wget: server returned error: HTTP/1.1 404 Not Found
Nothing to be done
An error ocurred, return value: 22.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget -q -P /opt/ipkg-RPfyri http://nw-dlcdnet.asus.com/asusware/arm/stable/gdbm_1.8.3-4_arm.ipk'
Failed to download gdbm. Perhaps you need to run 'ipkg update'?
ipkg install http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/gdbm_1.8.3-4_arm.ipk
the file downloaded and installed fine, but still does not work.
I started the tutorial from the begining and still nothing.
This is what i get when running "cherokee-admin -b"
admin@RT-AC68U-93A8:/tmp/home/root# cherokee-admin -b
[13/09/2014 22:26:30.245] (error) plugin_loader.c:194 - Something just happened
while opening a plug-in file | The operating system reported 'File not
found' while trying to load '/opt/lib/cherokee/libplugin_render_rrd.so'.
[13/09/2014 22:26:30.245] (error) plugin_loader.c:362 - Could not open the
'render_rrd' module | Either you are trying to use an unavailable
(uninstalled?) plugin, or there is a installation issue.
main_admin.c:407 - Could not initialize the server
Aah, just starting with the rt-ac68u with optware.
Cherokee is mentioned on Merlins site, did not know lighttpd is optware compatible.
Just want a http server to run, to create my own dropbox with a nice interface for all clients.
Anyway, tnx, will try that.
tnx,
Yes, that what i meant, will check it out tomorrow.
O btw, lighttpd runs on entware, and that not available for ARM.
Anyway a http server would be nice for future projects.
tnx,
Lighttpd is available on optware too
ipkg install lighttpd
Hi! I can't install cherokee with errors. hdd and flash drive ext4 formatted. router factory resetting. file plased on its folders. what i to do?
/tmp/home/root# ipkg install cherokee
Installing cherokee (1.0.19-2) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/cherokee_1.0.19-2_arm.ipk
If you're upgrading from pre 0.8, the configuration format has changed
Please use the new configuration files.
Configuring cherokee
Starting web server: cherokee
[19/03/2017 18:09:43.287] (error) plugin_loader.c:194 - Something just happened
found' while trying to load '/opt/lib/cherokee/libplugin_cgi.so'.
[19/03/2017 18:09:43.287] (error) plugin_loader.c:362 - Could not open the
'cgi' module | Either you are trying to use an unavailable (uninstalled?)
Couldn't read the config file: /opt/etc/cherokee/cherokee.conf
Successfully terminated.
