[TUTORIAL]CHEROKEE web server through optware
Cherokee is not updated anymore, install RMerlin firmware and Lighttpd or Nginx from Entware-NG or Optware-NG
and Lighttpd or Nginx installing error. Only have libcrypto.so.1.0.0 and libssl.so.1.0.0
ln -s libcrypto.so.1.0.0 libcrypto.so.0.9.8 (and ssl) not fix it
@RT-AC68U-C4F8:/tmp# ipkg install cherokee
Installing cherokee (1.0.19-2) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/cherokee_1.0.19-2_arm.ipk
If you're upgrading from pre 0.8, the configuration format has changed
Please use the new configuration files.
Configuring cherokee
Starting web server: cherokee
/opt/sbin/cherokee: can't load library 'libcrypto.so.0.9.8'
Successfully terminated.
@RT-AC68U-C4F8:/tmp# ipkg install nginx
Installing nginx (1.0.14-1) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/mbwe-bluering/cross/stable/nginx_1.0.14-1_arm.ipk
Configuring nginx
Starting web server: nginx
/opt/sbin/nginx: can't load library 'libssl.so.0.9.8'
all ok...but im asking me all the time...where i can upload my files to my webserver?
if i go via ftp to my hdd i cannot find any root directory or something else...? (/opt/share/www/cherokee)
where are all the files...index.html and so on?
If post #1 in this thread is still relevant, then:
If you have already a website created, just copy it to /opt/share/www/cherokee but first set write permission to folder:
chmod 777 /opt/share/www/cherokee
If you don't have a website, a good start is to download a template from web, like one from this site www.htmltemplates.net
Edit with your favorite HTML editor and publish.
yes i know...but i cant find no folders on my usbharddisk.
where are all these folders??? /opt/share/www/cherokee
for example...how can i connect my internal webspace with a ftp programm like filezilla?
are the files and folders not on my hdd?
i connect my hdd with 192.168.1.1 admin and password....but no folders and files from cherokee...?! :-(
They are usually outside the ftp/samba share location.
Use WinSCP to login with your router's credentials, make sure to select SCP as the protocol and have SSH enabled in Administration/System.
You'll find DocumentRoot to be it in the referenced path.
THX fpr your time anf help.
WINSCP ist working...im now in root, but its completly emtpy. no folders like share or www or gi-bin or files like index.html.....
im thinking im completly on a wrong way...:-(
/home/root is the volatile home directory of the root user on the router which is your username.
Go up two levels and you'll find the full directory structure of your router.
