[TUTORIAL] Native Transmission on asuswrt routers through optware
admin@RT-N66U:/tmp/mnt/sdb5/asusware# ls -l /jffs/scripts
-rwxrwxrwx 1 admin root 189 Oct 18 20:56 firewall-start
-rwxrwxrwx 1 admin root 33 Oct 18 22:00 post-mount
Ok, now
cat /jffs/scripts/firewall-start
Ok, now
admin@RT-N66U:/tmp/mnt/sdb5/asusware# cat /jffs/scripts/firewall-start
#!/bin/sh
iptables -I INPUT -p tcp --destination-port 9091 -j ACCEPT
iptables -I INPUT -p tcp --destination-port 51413 -j ACCEPT
iptables -I INPUT -p udp --destination-port 51413 -j ACCEPT
Took a screenshot aswell
Are you behind another router or something?
Try to change transmission port in settings.json and firewall-start
I changed port in settings.json to 51414, aswell as in /jffs/scripts/firewall-start to 51414. Still says closed oO
No the router is not behind a firewall or another router. I have my 100mbit wan connected directly into the router.
Yes, working links on www.asuswrt.eu
On tutorial step 4 wget, it loops with this error:
$ /opt/bin/wget -c -O /opt/etc/init.d/S95transmission http://goo.gl/cSA0os --no-check-certificate
--2014-10-26 00:36:33--  (try: 6)  https://www.asuswrt.eu/files/transmission/S95transmission
Connecting to www.asuswrt.eu (www.asuswrt.eu)|91.216.151.23|:443... connected.
WARNING: cannot verify www.asuswrt.eu's certificate, issued by `/C=IL/O=StartCom Ltd./OU=Secure Digital Certificate Signing/CN=StartCom Class 1 Primary Intermediate Server CA':
  Self-signed certificate encountered.
HTTP request sent, awaiting response... 200 OK
Length: 3781 (3.7K) [text/plain]
Saving to: `/opt/etc/init.d/S95transmission'
 0% [        ] 0           --.-K/s   in 0s
2014-10-26 00:36:35 (0.00 B/s) - Read error at byte 0/3781 (Invalid argument). Retrying.
Suggesting in "S95transmission" script change the disk evaluation loop as follows so it will work with disk labels too; (a router with 2 usb could support 4 low power pocket drives with usb hub in each usb port, thus c & d):
for i in "a1" "a2" "a3" "a4" "b1" "b2" "b3" "b4" "c1" "c2" "c3" "c4" "d1" "d2" "d3" "d4" ; do
        disk_path=`grep /dev/sd${i} /proc/mounts | awk '{print $2}'`
        if [ -d "${disk_path}" ] && [ ! -z "${disk_path}" ] ; then
                [ -z "${DIR_OK}" ] && DIR_OK="${disk_path}"
                if [ -d "${disk_path}/${REL_DLPATH}" ] ; then
                        DIR_DL="${disk_path}/${REL_DLPATH}"
                        break
                fi
        fi
done
Instead of awk could also use
cut -d " " -f 2
Then these lines can be uncommented:
[ ! -d "$DIR_CONF" ] && mkdir -p "$DIR_CONF"
[ ! -d "$DIR_DL1" ] && mkdir -p "$DIR_DL1"
[ ! -d "$DIR_DL2" ] && mkdir -p "$DIR_DL2"
[ ! -d "$DIR_DL3" ] && mkdir -p "$DIR_DL3"
[ ! -d "$DIR_LOG" ] && mkdir -p "$DIR_LOG"
I have a problem with Transmission on my RT-AC68U, I decided to reinstall it because the daemon was crashing all the time, but following again the steps i got some errors, of course i removed all the directories from my usb drive before the new installation, but here are the errors i get and were i'm not able to get further with the reinstallation, what's wrong?
admin@RT-AC68U:/tmp/home/root# /opt/bin/wget -c -O /opt/etc/init.d/S95transmission http://goo.gl/VCgvw2 --no-check-certificate
--2014-10-31 02:20:01-- http://goo.gl/VCgvw2
Resolving goo.gl (goo.gl)... 2a00:1450:400c:c05::8a, 85.113.229.170, 85.113.229.174, ...
Connecting to goo.gl (goo.gl)|2a00:1450:400c:c05::8a|:80... failed: Network is unreachable.
Connecting to goo.gl (goo.gl)|85.113.229.170|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://dl.dropboxusercontent.com/u/47669650/RT-N66U/Transmission/S95transmission [following]
--2014-10-31 02:20:01-- http://dl.dropboxusercontent.com/u/47669650/RT-N66U/Transmission/S95transmission
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 54.243.53.250, 107.20.198.79, 184.72.235.103, ...
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|54.243.53.250|:80... connected.
HTTP request sent, awaiting response... 302 FOUND
Cookie coming from dropbox.com attempted to set domain to dropbox.com
Location: https://dl.dropboxusercontent.com/u/47669650/RT-N66U/Transmission/S95transmission [following]
--2014-10-31 02:20:01-- https://dl.dropboxusercontent.com/u/47669650/RT-N66U/Transmission/S95transmission
/opt/bin/wget: symbol '__div0': can't resolve symbol
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|54.243.53.250|:443... connected.
WARNING: cannot verify dl.dropboxusercontent.com's certificate, issued by `/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 High Assurance Server CA':
Unable to locally verify the issuer's authority.
HTTP request sent, awaiting response... 404 Not Found
2014-10-31 02:20:02 ERROR 404: Not Found.
admin@RT-AC68U:/tmp/home/root# chmod 777 /opt/etc/init.d/S95transmission
admin@RT-AC68U:/tmp/home/root# /opt/etc/init.d/S95transmission start
admin@RT-AC68U:/tmp/home/root# /opt/etc/init.d/S95transmission stop
admin@RT-AC68U:/tmp/home/root# chmod 777 /opt/etc/transmission-daemon/settings.json
chmod: /opt/etc/transmission-daemon/settings.json: No such file or directory
I stopped to go on because of this errors.
Read again first line
I just copy and paste the output,
This is are the line i run from your guide using telnet from my MacAir:
ipkg update
ipkg upgrade
ipkg install transmission libiconv wget-ssl
rm -r /opt/etc/transmission-daemon/settings.json
/opt/bin/wget -c -O /opt/etc/transmission-daemon/settings.json http://goo.gl/PIHW2f --no-check-certificate
app_set_enabled.sh transmission yes
I copy the output from the 4th line, something goes wrong with the CA and then is missing the settings.json file, maybe is something changed?
This is are the line i run usually from your guide using telnet from my MacAir:
ipkg update
ipkg upgrade
Working links are on new site
Same problem for me!!
Which is the right line command to complete transmission install??
Thanks in advance
Thanks in advance
I follow this link and i could make it work again on my RT-AC68U:
https://www.asuswrt.eu/transmission-on-asuswrt-routers-through-optware/
when I start the transmission daemon from the command-line I get a warning message that it can't create "Transmission" dir due to the ready-only F.S. but still works.
I'd like if there is more troubleshooting about such issues and eventually updates, also the version is stuck on 2.82.
