[TUTORIAL] Native Transmission on asuswrt routers through optware
You already installed wget-ssl, continue with the next step
Thanks for your feedback,
But when I tried to '/opt/etc/init.d/S95transmission start', it displays as attachment.
Actually, I connected new USB HDD before install, is it cause this problem?
Send outputs from:
uname -a
mount
df
free
SWAP FILE
If transmission crashes sometimes "without reason", most probably router goes out of memory and this can be fixed by creating a swap partition but it's a little bit to complicated for most users and we will create a swap file instead, 256MB is more than enough:
cd /opt
dd if=/dev/zero of=swapfile bs=1024 count=262144
mkswap swapfile
chmod 0600 swapfile
swapon swapfile
To enable swap file when router booting, add this lines to /jffs/scripts/post-mount script
#!/bin/sh
swapon /opt/swapfile
To unmount add this lines to /jffs/scripts/services-stop script
#!/bin/sh
swapoff /opt/swapfile
chmod a+rx /jffs/scripts/post-mount
chmod a+rx /jffs/scripts/services-stop
I've created the swap file but I'm not sure where to place the commands in the post-mount and services-stop script files. There's already script data in those files. see below for what already exists in each of those files and advise where in those scripts I can place the swapon and swapoff commands. Thanks
post-mount
#!/bin/sh
if [ $1 = "/tmp/mnt/sda1" ]
then
ln -sf $1/entware /tmp/opt
fi
services-stop
#!/bin/sh
/opt/etc/init.d/rc.unslung stop
post-mount
#!/bin/sh
then
fi
services-stop
#!/bin/sh
post-mount
#!/bin/sh
then
fi
services-stop
#!/bin/sh
How can I add a delay in post-mount script in order for the transmission-daemon to wait for USB mounting?
I'm keep getting these errors after cold boot related to ...no data is found. please add a disk...
Does anyone know how to reallocate transmission log files?
It writes way too much data into syslog making it unreadable.
I've searched around, it appears in "/opt/etc/init.d/S95transmission" there is mention of /opt/var/log? But it doesn't look like this constant is intend to be edited. :confused:
There are 4 log levels:
0 = no logging
1 = error messages only
2 = info & error messages
3 = debug i.e. all messages
I guess you have "3" enabled.
I have not seen or edit anything relating to logging levels...... where can I change logging levels?
I would also like to not have transmission write to syslog.
I tried changing this but log still ends up in syslog.
#  DIR_LOG="/opt/var/log"
DIR_LOG="/mnt/dl/logs"
many thanks
many thanks
I'm not sure you can change log path but you may decrease log level to 1
Stop transmission
/opt/etc/init.d/S95transmission stop
Edit settings.json
nano /opt/etc/transmission-daemon/settings.json
Change
"message-level": 3,
to
"message-level": 1,
Save and start transmission again
thank you very much.
I had copied my settings.json file from my NAS, which seems to have set that setting to 2.
Post-mount is triggered only after usb disk are mounted, I think your problem is another.
Do you have another scripts maybe?
Post here output from:
mount
df
free
uname -a
Since this is live again, please take a look 3 posts above for my question.
Thanks!
mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sdb2 on /tmp/mnt/dataSD type ext3 (rw,nodev,noatime,data=ordered)
/dev/sdb1 on /tmp/mnt/entware type ext2 (rw,nodev,noatime)
/dev/sda1 on /tmp/mnt/data type ext3 (rw,nodev,noatime,data=ordered)
df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 25088 25088 0 100% /
tmpfs 119856 2632 117224 2% /tmp
devfs 119856 0 119856 0% /dev
/dev/mtdblock4 5632 388 5244 7% /jffs
/dev/sdb2 5291760 141720 4881224 3% /tmp/mnt/dataSD
/dev/sdb1 2124212 74792 1941516 4% /tmp/mnt/entware
/dev/sda1 615319352 481890144 102172744 83% /tmp/mnt/data
free
total used free shared buffers
Mem: 239712 175224 64488 0 5968
-/+ buffers: 169256 70456
Swap: 251648 2464 249184
uname -a
Linux RT-N66U 2.6.22.19 #1 Fri Jun 6 16:31:19 EDT 2014 mips GNU/Linux
All seams ok, you have 2 usb devices, try with only one, probably you need a script to mount devices by "uuid"
The thing is, I get this message only after reboot. I have to manually start all torrents and after that, until next reboot everything is OK
