My current setup is
WDA-2320 D-Link in PC
WBR-2310 Wireless Router connected to Internet
WBR-2310 is assigned 192.168.0.2 with a DHCP range of 192.168.0.100 to 110.
My Home PC is set to a static address of 192.168.0.100 via the WBR-2310
As you can tell my Main PC is connected to the internet Wireless via the WDA-2320 to the WBR-2310. Do to home configuration, there is no way I can hard wire the WBR-2310 to the Home PC.
I have a DSM-520 Multimedia Center Downstairs connected to the SSID for the WBR-2310.
I have One Terabyte of Music, Photos, and Music on a Raid 1 set of Hard drives on the home PC that I currently stream to the DSM-520 via the Home PC, wirelessly to the WBR-2310 and then wirelessly to the DSM-520
All my home computers/laptops are connected via wireless to the internet and a shared Drive and USB Printer on my home PC.
Problem -- When the DSM-520 is running and someone is connected wireless to the internet, the DSM-520 will freeze. Bandwidth problem. When no one is using the internet, then the DSM-520 Works great.
I have a second WBR-2310 wireless router that I have tried to use with the DSM-520. I have hard wired this router via a LAN port on the Router to the Ethernet Port on the PC. I have configured the second router with a different SSID and reassigned the address to 192.168.1.1 and DHCP to 192.168.1.100 to 102.
The DSM-520 sees the Multimedia server on the Computer via the second router and will connect. A IP address of 192.168.1.100 will be assigned to the DSM-520. But, the DSM-520 will not connect to the folders for music, photos or videos. It has error message on TV saying Unable to connect.
When I connect via router 1 to the PC, I can see the folders every time.
So what settings must I make on the second WBR-2310 router and/or PC to connect to the Media server folders on the PC via router 2. Will a cross over Ethernet cable do the trick and/or are other settings necessary.
I also want to use the online service on the DSM-520 multimedia center via the second router.
