PixelGizmo
Hello,
I'm hoping I'm in the right forum, I send me apologies if I'm not!
I've currently got an ASUS RT-AX88U plugged into a Virgin Media Hub 4 (using their Gig1 internet).
I'm trying to get some form of link aggregation in place to get around the 940MBit/sec ethernet theoretical maximum speed.
I've got VM Hub into modem mode and my RT-AX88U configured, but the Link Aggregation bit has thrown me.
I'm aware that the hub4 has an undocumented feature that allows the device to communicate back along multiple Ethernet connections in modem mod, the ASUS doesn't recognise the Link Aggregation.
I've been reading through a couple of forums:
and
in the second link the user who has successfully got this working has used a device in between their firewall (not an Asus) and the modem, a Mikrotik device.
I'm trying to get a similar result, but using a switch (ZyXel GS1900-8), I've set up a separate VLAN and moved 4 ports into LACP mode, with 2 ethernet connections to the ASUS, and 2 to the modem, shows Link aggregation at 2GBit, but tells me that my ISP's DHCP isn't working), I've got no internet throughput and the modem status page at is unreachable, meaning that its not successful in connecting to the modem.
I'm not too fussed about the ZyXel, I've just swapped it out for a Cisco SG300-10P as my core switch so I have the ZyXel lying around and through I'd give the ZyXel a new purpose.
Has anyone here had any experience in setting this up? I'm hoping I just need to tick/untick an option in the ZyXel, but I'm also aware that I may actually need to swap it out for another device to get this working.
Thanks in advance
Chris
How to make the most of a 1.15Gbps (Gig1) Virgin Media ISP
I have just upgraded my ISP to the latest Virgin Media (VM) offering which gives just over 1.1Gbps/50Mbps connection speeds. The supplied router comes with 4 x 1 gigabit ports as well as WiFi 5? It does not have a 10Gbe connection and it can be operated in Modem Only mode that would limit it...
forums.servethehome.com
1gig Rollout getting faster - Cable Forum
1000M 1gig Rollout getting faster Virgin Media Internet Service
www.cableforum.uk
Thanks in advance
Chris
