Clean out /jffs/scripts/dnsmasq.postconf and/or /jffs/configs/dnsmasq.conf.addAfter removing this script (uninstalling) I have no access to internet without defining specific DNS servers. Can't use my ISP DNS servers and must turn on DNS Filtering to route all devices via DNS servers I specified! What happened?
They are clean . :\ very strange... I did reboot after uninstall and it didn't workClean out /jffs/scripts/dnsmasq.postconf and/or /jffs/configs/dnsmasq.conf.add
IMPORTANT: It is recommended to REBOOT in order to complete the removal of unbound
You will be asked to confirm BEFORE proceeding with the REBOOT
rs = Restart (or Start) unbound s = Display unbound statistics (s=Summary Totals; sa=All)
e = Exit Script
Option ==> 2
y = Are you sure you want to uninstall unbound?
n = Cancel
e = Exit Script
Option ==> y
Uninstalling unbound
Removing firewall rules
KILLing unbound PID=1965
Removing Ad and Tracker Update cron job
Existing unbound package found. Removing unbound
Removing package unbound-control-setup from root...
Removing package unbound-control from root...
Removing package unbound-anchor from root...
Removing package unbound-daemon from root...
unbound Entware packages 'unbound-control-setup unbound-control unbound-anchor unbound-daemon' successfully installed
/opt/var/lib/unbound/adblock folder and all files removed
/opt/var/lib/unbound folder and all files removed
No files found to remove in /opt/etc/unbound
/opt/etc/unbound folder and all files removed
Removing unbound installer directives from 'dnsmasq.postconf'
Uninstall of unbound completed.
The router will now REBOOT to finalize the removal of unbound
After the REBOOT, review the DNS settings on the WAN GUI and adjust if necessary
Press Y to REBOOT or press ENTER to ABORT
If you do not choose to reboot, launchClean out /jffs/scripts/dnsmasq.postconf and/or /jffs/configs/dnsmasq.conf.add
service restart_dnsmasq
ls /jffs/configs/
cat /jffs/scripts/dnsmasq.postconf
#!/bin/sh
Script is working correctly. Rebooting is preferable if you have opted for more features.They are clean . :\ very strange... I did reboot after uninstall and it didn't work
cat /tmp/resolv.dnsmasq
Also check /jffs/scripts/firewall-start for the dns redirection.
Erm...Script is working correctly. Rebooting is preferable if you have opted for more features.
Option ==> 2
n = Cancel
e = Exit Script
Option ==> y
KILLing unbound PID=5735
Restarting dnsmasq.....
Didn't think the unbound installer script still modified 'firewall-start'Also check /jffs/scripts/firewall-start for the dns redirection.
A firewall restart would be necessary if ever enabling the redirect.Erm...
….actually, just in case the user does not reboot immediately after uninstalling unbound, the script does (silently) restart dnsmasq, however, it performs it after removing any unbound entries from 'dnsmasq.conf.add' but before removing the unbound entries from 'dnsmasq.postconf'
However, as you state, a REBOOT would fully honour the dnsmasq re-configuration.
Pushed v1.14 to correct this, and verbosely indicate that dnsmasq has been restarted.
Code:Option ==> 2 IMPORTANT: It is recommended to REBOOT in order to complete the removal of unbound You will be asked to confirm BEFORE proceeding with the REBOOT y = Are you sure you want to uninstall unbound? n = Cancel e = Exit Script Option ==> y Uninstalling unbound Removing firewall rules KILLing unbound PID=5735 Removing Ad and Tracker Update cron job Existing unbound package found. Removing unbound Removing package unbound-control-setup from root... Removing package unbound-control from root... Removing package unbound-anchor from root... Removing package unbound-daemon from root... unbound Entware packages 'unbound-control-setup unbound-control unbound-anchor unbound-daemon' successfully installed /opt/var/lib/unbound/adblock folder and all files removed /opt/var/lib/unbound folder and all files removed No files found to remove in /opt/etc/unbound /opt/etc/unbound folder and all files removed Removing unbound installer directives from 'dnsmasq.postconf' Restarting dnsmasq..... Uninstall of unbound completed. The router will now REBOOT to finalize the removal of unbound After the REBOOT, review the DNS settings on the WAN GUI and adjust if necessary Press Y to REBOOT or press ENTER to ABORT
Beware of early adopters.Didn't think the unbound installer script still modified 'firewall-start'![]()
If you check, there are no changes to the firewall.A firewall restart would be necessary if ever enabling the redirect.
I had understood the script. Thank you for this collaboration.Pushed v1.14 to correct this, and verbosely indicate that dnsmasq has been restarted.
Well the script still contains the (unused) 'Redirect_outbound_DNS_requests()' function which only deletes the two redirect rules it implemented, so whilst it may be prudent, but simply deleting the redirect rules seemed to suffice without a disruptive firewall restart?A firewall restart would be necessary if ever enabling the redirect.
Older versions (Dec 20) automatically applied the changes without the complete unbound_installer comment. So the current script would not remove those lines.If you check, there are no changes to the firewall.
Right. It turns out that applying IPTABLES rules runs the risk of compatibility with future releases of FW Merlin. Prudently, DNSFILTER is sufficient.Well the script still contains the (unused) 'Redirect_outbound_DNS_requests()' function which only deletes the two redirect rules it implemented, so whilst it may be prudent, but simply deleting the redirect rules seemed to suffice without a disruptive firewall restart?
Welcome To SNBForums
