Unbound - Authoritative Recursive Caching DNS Server
Interesting, when I allow 2 threads - I get two different responses 1 from each thread of Unbound. It takes three tries to hit cache, dig result's DNS IP shows the router both times. I see two Unbound process IDs when running top command. The behavior immediately reverts when changing back to 1 thread. Reboot did not help when threads set to 2. Reverted with other recommended changes intact for now
I can confirm - with more then one thread the caching quality was decreased. It's look like - the different thread use the different cache space ...
I don't think it's really needed on a home device. From the unbound github page...
The transmission-bt package is compiled with libevent. Earlier versions of unbound were supported. But there is consensus that it is an unnecessary alternative because of the various models of ARM or MIPS routers.
The default setting has been thoroughly tested. It's trustable. Thread "1" makes it disabled.
I am trying to compile version 1.9.5. Without the option of libevent for better compatibility on many routers. I only encounter problems with organizing dependent libraries in recent entware.
Another helpful set of logging commands I've made for easy switching of logging on/off, or switching Unbound on/off (these go in /jffs/configs/profile.add):
unboundlog() {
        unbound-control verbosity 2
        unbound-control set_option log-queries: yes
        unbound-control set_option log-replies: yes
        tail -50 -F /opt/var/lib/unbound/unbound.log
unboundnolog() {
        unbound-control verbosity 1
        unbound-control set_option log-queries: no
        unbound-control set_option log-replies: no
unbounddisable() {
        /opt/etc/init.d/S61unbound stop
        service restart_dnsmasq
        /opt/etc/init.d/S02haveged stop
        sed -i "s/^ENABLED=yes/ENABLED=no/" /opt/etc/init.d/S61unbound
        sed -i "s/^ENABLED=yes/ENABLED=no/" /opt/etc/init.d/S02haveged
unboundenable() {
        sed -i "s/^ENABLED=no/ENABLED=yes/" /opt/etc/init.d/S02haveged
        sed -i "s/^ENABLED=no/ENABLED=yes/" /opt/etc/init.d/S61unbound
        /opt/etc/init.d/S02haveged start
        /opt/etc/init.d/S61unbound start
Another useful unbound.conf configuration setting for log reading:
log-time-ascii: yes
Great contribution. We need a report pattern. We are trying to organize a report with Zabbix.
Next release unbound on entware 1.9.6 with support libevent. New package. unbound-daemon-heavy. Waiting
"contains the Unbound daemon including 'libevent' and 'libpthread' to better handle large networks with heavy query loads."
PKG_NAME:=unbound
PKG_VERSION:=1.9.6
PKG_RELEASE:=1
define Package/unbound-daemon-heavy/description
  This package contains the Unbound daemon including 'libevent' and
endef
PKG_NAME:=unbound
PKG_VERSION:=1.9.6
PKG_RELEASE:=1
endef
It looks like Entware team doesn’t build that package even though it’s available from the Openwrt feed. I had previously looked into why unbound-checkconf has also disappeared in the last Unbound update a few months ago.
https://github.com/Entware/Entware/blob/master/configs/armv7-2.6.config#L5537
unboundlog() {
unboundnolog() {
unbounddisable() {
unboundenable() {
log-time-ascii: yes
Approved. Logs go to FW GUI General Log. I agree with the implementation. You have to check if @Martineau agrees.
thank you
this works very well
Compare unbound's native adblock with the NextDNS implementation. There is a big difference in latency. Unbound offers NXDOMAIN answers with more privacy.
cache-min-ttl: 0
Users of DNS-based load balancing or DDoS-prevention may require short TTLs: TTLs may be as short as five minutes, although 15 minutes may provide sufficient agility for many operators. Shorter TTLs here help with agility; they are an exception to our first recommendation of longer TTLs.
cache-min-ttl: 900 => 15 minutes
Ad and tracker's blocking options available on Unbound. Not only the block is enough, but the answer of this block. The native adblock script installer uses the static option.
refuse
Send an error message reply, with rcode REFUSED. If there is
a match from local data, the query is answered.
static
If there is a match from local data, the query is answered.
Otherwise, the query is answered with nodata or nxdomain.
For a negative answer a SOA is included in the answer if
present as local-data for the zone apex domain.
always_nxdomain
Like static, but ignores local data and returns nxdomain for
the query.
It might get noisy in syslog if someone forgets to disable logging. I always have the logfile path enabled in my unbound.conf. It would be nice to separate log messages from query logs as someone has already suggested on Github.
N.B. My unbounddisable function assumes that the dnsmasq.postconf is checking to verify unbound is running before making the modifications. This allows it to safely revert to GUI DNS settings by restarting dnsmasq after Unbound is stopped. With the current script, those checks are not yet implemented in the Check_dnsmasq_postconf function (present but commented out).
Unbound Installer v1.16 available.
Addresses the following as proposed by @dave14305
My current position is that to keep the Unbound cache fresh, you don't want dnsmasq caching in front of it, so I delete the dnssec options to allow zero cache.
Since there is no one else to trust in between dnsmasq and unbound, I am fine to proxy-dnssec the Unbound responses.
OK, so the dnsmasq error I experienced/reported
dnsmasq[15203]: cannot reduce cache size from default when DNSSEC enabled" >> /jffs/scripts/unbound.postconf
dnsmasq[15203]: FAILED to start up"
is actually by design as described in the dnsmasq man page.
So v1.16 now removes the dnsmasq 'dnssec' directive to allow disabling dnsmasq caching (cache-size=0)
v1.16 now uncomments the 'if' clause in 'unbound.postconf', however, I could not get unbound to work when it attempts to use the dynamiclly retrieved $UNBOUNDLISTENADDR rather than the static "127.0.0.1#53535"
log-time-ascii: yes
I am reluctant to mess with external files, and would prefer to keep the features within the unbound installer script.
v1.16 now incorporates your suggestion and allows (human-friendly timestamped) unbound logging to be dynamically ENABLED/DISABLED see menu below.
Since the logging is dynamic (using unbound-control), being lazy I do not modify the ACTIVE 'unbound.conf' but instead have added the ability to dynamically Query/Set any of the unbound options from the menu.
This does mean that the 'v' option to view the ACTIVE 'unbound.conf' may not reflect the current state of the unbound options.
However, this does mean that if an unbound option is incorrectly set, using the 'rl' option should back-out the damage together with the 'rs' command.
unbound (pid 8516) is running... uptime: 0 Days, 01:50:26 version: 1.9.3
1  = Update ('/opt/var/lib/unbound/') unbound Configuration     l  = Show unbound LIVE log entries (lx=Disable Logging)
2  = Remove Existing unbound Installation                       v  = View ('/opt/var/lib/unbound/') unbound Configuration (vx=Edit)
        rl = Reload unbound Configuration (Doesn't interrupt/halt unbound)
        oq = Query unbound Configuration option e.g 'oq verbosity' (ox=Set) e.g. 'ox log-queries yes'
rs = Restart (or Start) unbound                                 s  = Display unbound statistics (s=Summary Totals; sa=All)
e  = Exit Script
@Martineau I need to add a new list with CNAME adblock support, but the package comes zipped in the script.
