As the logs capture queries and everything, the file expands. To guarantee performance and check for problems, with each adblock update, the LOG file is removed.
Unbound/Adblock updated with the addition of domains and options in Unbound for blocking efficiency. I am implementing the blocking by CNAME Cloaking non ECS. For now, for my false positive tests.
Particularly, I don't see the need for LOG's for a long time. It goes from each user. It is difficult to organize an LOG policy for the ideal DNS. For the unbound, the ideal would be LOG's of errors only. However, there are users who want to check queries, etc.How large will the unbound log get? Right now mine is a little over 82 megs.
It blocks just as much as you tell it to. And I have no doubt that Diversion works - as long as requests go to the routers DnsmasqDiversion caused too many issues with my wife’s web surfing and I could never tell if AD Block was actually doing anything so I uninstalled it after a couple of days.
Via SSH: you can add allowed hosts to the file:How is this done in ADblock?
nano /opt/var/lib/unbound/adblock/permlist
nano /opt/var/lib/unbound/adblock/blockhost
It blocks just as much as you tell it to. And I have no doubt that Diversion works - as long as requests go to the routers Dnsmasq![]()
Block custom domains at:Code:nano /opt/var/lib/unbound/adblock/permlist
Code:nano /opt/var/lib/unbound/adblock/blockhost
Now I can rest in peace, thanks Mr. Smokey.Oh yes, Diversion definitely works! I just got tired of hearing my wife complain about her “ internet “ not working properly.
I loved it!
That has yet to be determined. I am the old timer here, while @rgnldo edges his way into that field. We are working on it.Can you elaborate on the differences of the “objectives” between ADblock and Diversion, ie. what is the goal of each? I am sure I am not the only one to possibly confuse the intent of the two programs.
I have a lot to thank @thelonelycoder. The unbound adblock has great influences from Diversion, it is our inspiration. The initiative appeared only to favor the work of the unbound.That has yet to be determined. I am the old timer here, while @rgnldo edges his way into that field. We are working on it.
In ADblock, is there a way to place my wife’s iPhone and laptop in an exclusion list so she will not be filtered? All my devices are assigned static IPs. The only caveat is I am running IPv6.
There are some safe suggestions:
- Create a vlan;
- Create a guest network;
- change add static DNS on devices.
| Thread starter | Title | Forum | Replies | Date |
| H | AdGuard Home+Unbound in proxmox does not work properly with Asus AX88U Pro | Asuswrt-Merlin | 6 | |
| S | AdguardHome + Unbound on Pi4 Correct DNS settings | Asuswrt-Merlin | 6 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
