Unbound - Authoritative Recursive Caching DNS Server
I'm creating a new post here because there are too many characters to update post 1042 above. :)
The unbound.conf file I'm using right now is
(Please use this only as an example for an RT-AX88U and an ISP with IPv6 connectivity).
# rgnldo User Install Custom Version vx.xx (Date Loaded by unbound_manager Tue Feb  4 17:41:31 MST 2020)
server:
# port to answer queries from
port: 53535
# integration LOG's
verbosity: 2
logfile: "/opt/var/lib/unbound/unbound.log"
log-time-ascii: yes
log-queries: yes
log-replies: yes
do-ip4: yes
#do-ip6: no
do-udp: yes
do-tcp: yes
# don't be picky about interfaces but consider your firewall
interface: 0.0.0.0
access-control: 0.0.0.0/0 refuse
access-control: 127.0.0.0/8 allow
access-control: 10.0.0.0/8 allow
access-control: 172.16.0.0/16 allow
access-control: 192.168.0.0/24 allow
# RFC1918 private IP address - Protects against DNS Rebinding
private-address: 127.0.0.0/8
private-address: 169.254.0.0/16
private-address: 10.0.0.0/8
private-address: 172.16.0.0/12
private-address: 192.168.0.0/16
# integration IPV6
 do-ip6: yes
 interface: ::0
 access-control: ::0/0 refuse
 access-control: ::1 allow
 private-address: fd00::/8
 private-address: fe80::/10
# perform a query against AAAA record exists
    module-config: "dns64 validator iterator"
    dns64-prefix: 64:FF9B::/96
# no threads and no memory slabs for threads
num-threads: 1
msg-cache-slabs: 2
rrset-cache-slabs: 2
infra-cache-slabs: 2
key-cache-slabs: 2
# tiny memory cache
key-cache-size: 8m
msg-cache-size: 8m
rrset-cache-size: 16m
cache-max-ttl: 21600
cache-min-ttl: 5
prefetch: yes
prefetch-key: yes
serve-expired: yes
serve-expired-ttl: 3600
incoming-num-tcp: 600
outgoing-num-tcp: 100
ip-ratelimit: 100
# Options for integration with TCP/TLS Stubby
# udp-upstream-without-downstream: yes
# prefetch
prefetch: yes
prefetch-key: yes
minimal-responses: yes
# gentle on recursion
hide-identity: yes
hide-version: yes
do-not-query-localhost: no
qname-minimisation: yes
harden-glue: yes
harden-below-nxdomain: yes
rrset-roundrobin: yes
aggressive-nsec: yes
deny-any: yes
# Self jail Unbound with user "unbound" to /var/lib/unbound
username: "nobody"
directory: "/opt/var/lib/unbound"
chroot: "/opt/var/lib/unbound"
# The pid file
pidfile: "/opt/var/run/unbound.pid"
# ROOT Server's
root-hints: "/opt/var/lib/unbound/root.hints"
# DNSSEC
auto-trust-anchor-file: "/opt/var/lib/unbound/root.key"
# Adblock blacklist
#include: /opt/var/lib/unbound/adblock/adservers
#include: /opt/var/lib/unbound/adblock/firefox_DOH
remote-control:
control-enable: yes
control-interface: 127.0.0.1
control-port: 953
server-key-file: "/opt/var/lib/unbound/unbound_server.key"
server-cert-file: "/opt/var/lib/unbound/unbound_server.pem"
control-key-file: "/opt/var/lib/unbound/unbound_control.key"
control-cert-file: "/opt/var/lib/unbound/unbound_control.pem"
#forward-zone:
#   name: "."
#   forward-addr: 127.0.0.1@5453
#   forward-addr: 0::1@5453 # integration IPV6
auth-zone:
    url: "https://www.internic.net/domain/root.zone"
    fallback-enabled: yes
    for-downstream: no
    for-upstream: yes
    zonefile: root.zone
The router was rebooted with 2 days and 12 hours of uptime in my previous post above.
The cache hit ratio was 87% in unbound_manager 's'.
Before rebooting, I did notice the changes I had made, but after the reboot, they are even more apparent and so far, this is only with a 41% cache hit ratio too. :)
No matter whether surfing the web, accessing the NAS, or using PuTTY to access amtm, ChannelHog or unbound_manager, the experience is obviously faster and more 'snappy'. :)
The only thing missing is the ability to have unbound in Scribe, but the log grows too large, too fast and crashes the web GUI still. :(
The network responsiveness now rivals any corporate or city network I've ever used. Can it get any better?
I'm going to buy a second RT-AX88U router (hopefully in the next few months) and see if AiMesh is all it's cracked up to be. :)
What I did:
Log = no
Integrate Stubby = no
Adblocker = no
Disable Firefox DoH = y
Customise cpu = y
Sorry for all the questions. But what you've listed there, where do I find those settings? Thanks for your time :)
@dave14305 thank you. I also updated the post above with the changes.
unbound_manager shows no issues either with the updated config file. :)
thanks for all this info. Unbound_manager also showing no errors
@L&LD
When doing a dns Leak test, what are you getting? WAN IP or Cloudfare
@L&LD
I have identical unbound setup to @L&LD - [except IP6 disabled in mine] - and I get WAN ip address in response to dns leak tests.
Confused me to begin with :eek: ... but now embarrassed to admit it :oops:. ;).
I simply ran install script from Github - took same options described by L&LD - but only added the "auth-zone" section to the bottom of my unbound.config file ... and the addition he mentions to init-start in /jffs/scripts.
Interestingly - my system with unbound does not score as well as it used to before unbound on this DNSSEC test ...
https://rootcanary.org/test.html :confused: - still use Quad9 for DoT under WAN settings!
Once you have SSH into your router, & copy & pasted the link from here,
https://github.com/MartineauUK/Unbound-Asuswrt-Merlin/blob/master/Readme.md
Select ‘i’ for install, then you will be asked questions.
Answer either ‘y’ for yes, or press ‘enter’ for no.
What I answered is in my post above.:)
NB, no other tweaks or modifications made, I’m just running Unbound ‘as is’.
That's all I will do as well. I'm no wiz at this stuff, so I play it safe. Thanks for the help.
@kernol here is my rootcanary.org results.
How are yours different?
Mine precisely the same as yours {Thumbs-Up}.
However - prior to Unbound my scores looked like this ...
@kernol okay, I want that too! :)
@kernol why aren't you still using Quad9 then?
I am - but unbound install has an impact on DNSSEC results.
If I uninstall unbound - I get back to the same results shown on my best scores above.
Install unbound again - and boom - back to the lesser scores.
It makes no difference whether I ask unbound to bind with stubby or not - same lesser scores.
@L&LD - you can have unbound in Scribe [option is available under @Martineau unbound install script] - but clearly not the full live logs which will certainly crash the webgui. We will have to wait for the combo of @Martineau and @Jack Yaz to give us an unbound webpage in the gui to show stats etc.
At this time the unbound script option for Scribe simply injects an unbound script into /opt/entware/etc/syslog-ng.d/ - but does not provide a script for logrotate. I basically "cloned" the pixelserv logrotate script and dropped it into /opt/entware/etc/logrotate.d/
Works fine in Scribe - and at least gives an indication that unbound is running and will track any activities invoked through unbound_manager.
