Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
YT blocking works nicely.
What does
added 32 datas
mean when running
/opt/var/lib/unbound/adblock/gen_ytadblock.sh
What does
added 32 datas
mean when running
I believe this is the current number of YT IP domains forced to the YT IP Address
You can view the local-datas loaded into unbound
unbound-control list_local_data | grep -F "googlevideo.com" | awk 'END{print "Total="NR} { print NR, $0 }''
Hmmm, might be worth adding this metric to the '?' display ? ;)
[✔] YouTube Ad Blocking (Forcing to use YT IP 173.194.135.104) Count=nn
I believe that would be consistent with:
 [✔] Ad and Tracker Blocking (No. of Adblock domains=55203,Blocked Hosts=0,Whitelist=19)
People finding YT ad blocking is working well? If so, I will move the script to my master branch from the dev branch.
Please reply with your findings.
Whats difference between unbound YT blocker and using diversion YT blocker? Is it the same script but separate for those who prefer unbound with ad blocking as opposed to unbound with diversion for ad blocking?
Its the same idea but executed differently... Diversion lifts the domains from the dnsmasq.log and unbound lifts them from a cache dump
Any idea what the logic is behind which YT IP address is chosen ? Eg when Unbound is primary DNS for all LAN clients my YT IP address is 220.233.204.109. When dnsmasq is enabled and Diversion is active The forced IPv4 address for YT is: 173.194.28.9
For unbound it simply uses the first one it finds in the initial cache dump
echo "No stored IP in file $ipYTforce, checking cache for an ip..."
    unbound-control dump_cache | awk '/.*\.googlevideo.*\.[0-9].*\./{print $5;exit}' > "$ipYTforce"
I haven't looked at the diversion code, but im guessing it uses the first one it finds in some way too.
The services-start entries for adblock and ytadblock are as below when these services are enabled in unbound -
cru a ytadblock "*/5 * * * * "/opt/var/lib/unbound/adblock/gen_ytadblock.sh"    # unbound_manager
cru a adblock "0 5 * * * "/opt/var/lib/unbound/adblock/gen_adblock.sh"    # unbound_manager
I believe they should be
cru a ytadblock "*/5 * * * * /opt/var/lib/unbound/adblock/gen_ytadblock.sh"    # unbound_manager
cru a adblock "0 5 * * * /opt/var/lib/unbound/adblock/gen_adblock.sh"    # unbound_manager
Seems to be working well here
Well if you attempted to refer to either device by name, it wouldn't be possible, however by IP address it should.....
e.g. this should work
nslookup 192.168.1.101
but what would you specify in the following command to find out what IP Address is assigned to the named device on your local domain?
nslookup ??????.AC86U.
Have you actually given a name to each of the two devices using 'dnsmasq.conf.add' or perhaps 'dnsmasq.postconf'?
glehel@AC86U-VPN:/tmp/home/root# nslookup Zara-Moto-G.SAFENET-AC86U.
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 192.168.1.112 Zara-Moto-G
working! I added manual domain line in unbound.conf.localhosts all ip!
A query for @juched here ..... just doing some reading about local-zone and local data, the documentation says that a local zone contains local data
local-zone: <zone> <type>
              Configure  a  local zone. The type determines the answer to give
              if there is no  match  from  local-data.  The  types  are  deny,
              refuse,  static, transparent, redirect, nodefault, typetranspar-
              ent, inform, inform_deny,  inform_redirect,  always_transparent,
              always_refuse, always_nxdomain, noview, and are explained below.
              After that the default settings are listed. Use  local-data:  to
              enter  data  into  the  local  zone. Answers for local zones are
              authoritative DNS answers. By default the zones are class IN.
local-data: "<resource record string>"
            Configure  local data, which is served in reply to queries for it.
            The query has to match exactly unless you configure the local-zone
            as  redirect.  If  not matched exactly, the local-zone type deter-
            mines further processing. If local-data is configured that is  not
            a  subdomain  of a local-zone, a transparent local-zone is config-
            ured.  For record types such as TXT,  use  single  quotes,  as  in
            local-data: 'example. TXT "text"'.
Would it be better to use a redirect zone for YT ads like the example below, or is it sufficient to just use local data as you have an exact match?
## DnsSpoof of unwanted or restricted sites
local-zone: "doubleclick.net" redirect
local-data: "doubleclick.net A 10.0.0.111"
local-zone: "facebook.com" redirect
local-data: "facebook.com A 10.0.0.111"
Im assuming you can get away with just creating a local zone for the adblocking because there will be no matching local data and the nxdomain will be provided as default zone behaviour.
always_nxdomain
                 Like static, but ignores local data and returns nxdomain  for
                 the query.
local-zone: "000owamail0.000webhostapp.com" always_nxdomain
local-zone: "000tristanprod.free.fr" always_nxdomain
local-zone: "005.free-counter.co.uk" always_nxdomain
local-zone: "006.free-counter.co.uk" always_nxdomain
local-zone: "006.freecounters.co.uk" always_nxdomain
local-zone: "007.free-counter.co.uk" always_nxdomain
local-zone: "007angels.com" always_nxdomain
local-zone: "008.free-counter.co.uk" always_nxdomain
local-zone: "008.free-counters.co.uk" always_nxdomain
local-zone: "00author.com" always_nxdomain
local-zone: "00go.com" always_nxdomain
local-zone: "00it.com" always_nxdomain
Awesome teamwork on this script and feature. I could use some help with facebook being blocked. I don't use unbound adblock or the firewall feature. I followed dnsmasq but nothing was being blocked:
May  9 22:23:53 dnsmasq[14483]: query[A] www.facebook.com from 192.168.50.129
May  9 22:23:53 dnsmasq[14483]: forwarded www.facebook.com to 127.0.0.1
May  9 22:23:53 dnsmasq[14483]: reply www.facebook.com is <CNAME>
May  9 22:23:53 dnsmasq[14483]: reply star-mini.c10r.facebook.com is 157.240.11.35
May  9 22:23:57 dnsmasq[14483]: query[A] mqtt.c10r.facebook.com from 192.168.50.230
May  9 22:23:57 dnsmasq[14483]: forwarded mqtt.c10r.facebook.com to 127.0.0.1
May  9 22:23:57 dnsmasq[14483]: reply mqtt.c10r.facebook.com is 157.240.11.12
May  9 22:23:58 dnsmasq[14483]: query[A] www.facebook.com from 192.168.50.129
May  9 22:23:58 dnsmasq[14483]: forwarded www.facebook.com to 127.0.0.1
May  9 22:23:58 dnsmasq[14483]: reply www.facebook.com is <CNAME>
May  9 22:23:58 dnsmasq[14483]: reply star-mini.c10r.facebook.com is 157.240.11.35
May  9 22:23:58 dnsmasq[14483]: query[AAAA] www.facebook.com from 192.168.50.129
May  9 22:23:58 dnsmasq[14483]: reply star-mini.c10r.facebook.com is 2a03:2880:f10d:183:face:b00c:0:25de
Thats an example just following "facebook". The browser returns the server stopped responding error...So I turned off Diversion, didn't make a difference, so I turned off unbound and I could access facebook again.
Many thanks, I've pushed Hotfix
Version=3.11
Github md5=0169d1a43328ea13b4b559a25c4a3825
Server: 127.0.0.1
Thanks for the feedback.
So how is 'Zara-Moto-G' actually defined/assigned when only using dnsmasq?
manual edit unbound.conf.localhosts,
the hostname is the same as the name in dnsmasq.
local-data: "Zara-Moto-G.SAFENET-AC86U. IN A 192.168.1.112"
local-data-ptr: "192.168.1.112 Zara-Moto-G"
My question is "How does dnsmasq assign the name?"
Can you print the record from '/etc/dnsmasq.conf'
I don't do consistent, well apart from perpetually issuing Hotfixes due to stupid typos or brain-dead coding.:rolleyes:
Cosmetic Hotfix
Version=3.11
Github md5=1187ed25ad68aa4d65d95add663de1e1
