Mutzli
Bad timingCurrently; bin.entware.net is down that's why we can't update eEntware package list which causes installation/update fails
how does one force a entware pkgs re download?bin.entware.net has been down for several hours, apparently after a major hardware failure. Just speculating, but it may be that the most recent downloads could have been from a system about to fail and may themselves be corrupt. Once the repository is back up it may be sensible to re-download any recent updates.
A VERY good question (and not one I know the correct answer to).how does one force a entware pkgs re download?
thanks
unbound (pid 1450) is running... uptime: 0 Days, 00:03:06 version: 1.10.1 # rgnldo Github Version=v1.10 Martineau update (Date Loaded by unbound_manager Sat Jun 20 10:42:05 DST 2020)
1 = Update unbound files and configuration 5 = Install Ad and Tracker blocker (Ad Block)
2 = Remove unbound/unbound_manager 6 = Uninstall Graphical Statistics GUI Add-on TAB
3 = Stop unbound 7 = Disable DNS Firewall [?]
4 = Show unbound statistics 8 = Install YouTube Ad blocker
? = About Configuration
v = View ('/opt/var/lib/unbound/'unbound.conf)
e = Exit Script [?]
E:Option ==> 1
13:11:33 Saving unbound cache to '/opt/share/unbound/configs/cache.txt'
Router Configuration recommended pre-reqs status:
[✔] Swapfile=2097148 kB
[✔] DNS Filter=ON
[✔] DNS Filter=ROUTER
[✔] WAN: Use local caching DNS server as system resolver=NO
[✔] Enable local NTP server=YES
[✔] Enable DNS Rebind protection=NO
[✔] Enable DNSSEC support=NO
Options:
[✔] unbound CPU/Memory Performance tweaks
[✔] Firefox DNS-over-HTTPS (DoH) DISABLE/Blocker
[✔] Router Graphical GUI statistics TAB installed
[✔] unbound-control FAST response ENABLED
UPDATEing unbound
Entware package list successfully updated
Package unbound-checkconf (1.10.1-1) installed in root is up to date.
Installing unbound-control-setup (1.10.1-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/armv7sf-k2.6/unbound-control-setup_1.10.1-1_armv7-2.6.ipk
Package unbound-control (1.10.1-1) installed in root is up to date.
Package unbound-anchor (1.10.1-1) installed in root is up to date.
Package unbound-daemon (1.10.1-1) installed in root is up to date.
Collected errors:
* opkg_download: Failed to download http://bin.entware.net/armv7sf-k2.6/armv7sf-k2.6/unbound-control-setup_1.10.1-1_armv7-2.6.ipk, wget returned 8.
* opkg_install_pkg: Failed to download unbound-control-setup. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package unbound-control-setup.
***ERROR occurred installing unbound
+1bin.entware.net is up again!
Edit:
There seems to be a problem when "1" installing unbound:
Code:unbound (pid 1450) is running... uptime: 0 Days, 00:03:06 version: 1.10.1 # rgnldo Github Version=v1.10 Martineau update (Date Loaded by unbound_manager Sat Jun 20 10:42:05 DST 2020) 1 = Update unbound files and configuration 5 = Install Ad and Tracker blocker (Ad Block) 2 = Remove unbound/unbound_manager 6 = Uninstall Graphical Statistics GUI Add-on TAB 3 = Stop unbound 7 = Disable DNS Firewall [?] 4 = Show unbound statistics 8 = Install YouTube Ad blocker ? = About Configuration v = View ('/opt/var/lib/unbound/'unbound.conf) e = Exit Script [?] E:Option ==> 1 13:11:33 Saving unbound cache to '/opt/share/unbound/configs/cache.txt' Router Configuration recommended pre-reqs status: [✔] Swapfile=2097148 kB [✔] DNS Filter=ON [✔] DNS Filter=ROUTER [✔] WAN: Use local caching DNS server as system resolver=NO [✔] Enable local NTP server=YES [✔] Enable DNS Rebind protection=NO [✔] Enable DNSSEC support=NO Options: [✔] unbound CPU/Memory Performance tweaks [✔] Firefox DNS-over-HTTPS (DoH) DISABLE/Blocker [✔] Router Graphical GUI statistics TAB installed [✔] unbound-control FAST response ENABLED UPDATEing unbound Entware package list successfully updated Package unbound-checkconf (1.10.1-1) installed in root is up to date. Installing unbound-control-setup (1.10.1-1) to root... Downloading http://bin.entware.net/armv7sf-k2.6/armv7sf-k2.6/unbound-control-setup_1.10.1-1_armv7-2.6.ipk Package unbound-control (1.10.1-1) installed in root is up to date. Package unbound-anchor (1.10.1-1) installed in root is up to date. Package unbound-daemon (1.10.1-1) installed in root is up to date. Collected errors: * opkg_download: Failed to download http://bin.entware.net/armv7sf-k2.6/armv7sf-k2.6/unbound-control-setup_1.10.1-1_armv7-2.6.ipk, wget returned 8. * opkg_install_pkg: Failed to download unbound-control-setup. Perhaps you need to run 'opkg update'? * opkg_install_cmd: Cannot install package unbound-control-setup. ***ERROR occurred installing unbound
The Entware server is up again, but files are missing and some are possibly corrupt. For now I would just wait before attempting to do any updates or installs until they say that everything is back to normal.I get the very same think ... I tried to run opkg update separate but when i go back and try to install unbound i get the same error.
First I uninstalled Unbound installer => Reboot => Updated the entware packages via Diversion => Install Unbound =>
* opkg_download: Failed to download http://bin.entware.net/aarch64-k3.10/aarch64-k3.10/unbound-daemon_1.10.1-1_aarch6.
* opkg_install_pkg: Failed to download unbound-daemon. Perhaps you need to run 'opkg update'?
* opkg_install_cmd: Cannot install package unbound-daemon.
Any thoughts?
There has to be an uninstall routine for unbound, even if bin.entware.net is not reachable.
We cannot rely on it staying online forever.
Like I said before ... be patient ...
bin.entware.net back up and seems fully functional.
Yes. Uninstalled Unbound, re-booted router, Install Unbound and still get that same message. "Warning Entware NTP Server installed but not running". On the Router Admin panel have "Enable Local NTP Server = Yes" and "Intercept NTP Client Requests = No".Easiest? Did you reboot the router?
Welcome To SNBForums
