Unbound unbound_manager (Manager/Installer utility for unbound - Recursive DNS Server)
How do I get the "Addons" tab back?
I already had it, but after a router reboot, the Addons tab is gone. (Router uptime was 14 days)
I can't remember if I have accidentally "unìnstalled" the tab? Is this even possible?
Edit:
I started unbound_manager now it says this
1  = Update unbound Installation  ('/opt/var/lib/unbound/')
2  = Update unbound Installation Advanced Mode ('/opt/var/lib/unbound/')
3  = Advanced Tools
e  = Exit Script
E:Option ==> s
        ***ERROR unbound NOT running! - option unavailable
Strange...
Doesn't unbound automatically start after a router reboot?
Edit2:
I tried to reinstall the GUI, but these errors appeared:
unbound (pid 11424) is running... uptime: 0 Days, 00:02:25 version: 1.9.6 # rgnldo Github Version=v1.06 Martineau update (Date Loaded by unbound_manager Sun Mar 1 12:40:08 MEZ 2020)
3  = Advanced Tools
e  = Exit Script
E:Option ==> sgui
Do you want to add router GUI TAB to display stats?
        Reply 'y' or press [Enter]  to skip
y
        Installing @juched's GUI TAB to display unbound stats.....
        unbound_stats.sh downloaded successfully
        unboundstats_www.asp downloaded successfully
        Mounting Unbound_Stats.sh WebUI page as user1.asp
/jffs/addons/unbound/unbound_stats.sh: line 305: p: not found
sed: /tmp/menuTree.js: No such file or directory
grep: /tmp/menuTree.js: No such file or directory
sed: invalid option -- 1
BusyBox v1.25.1 (2020-02-11 07:40:58 MSK) multi-call binary.
Usage: sed [-inrE] [-f FILE]... [-e CMD]... [FILE]...
or: sed [-inrE] CMD [FILE]...
        -e CMD  Add CMD to sed commands to be executed
        -f FILE Add FILE contents to sed commands to be executed
        -i[SFX] Edit files in-place (otherwise sends to stdout)
                Optionally back files up, appending SFX
        -n      Suppress automatic printing of pattern space
        -r,-E   Use extended regex syntax
If no -e or -f, the first non-option argument is the sed command string.
Remaining arguments are input files (stdin if none).
mount: mounting /tmp/menuTree.js on /www/require/modules/menuTree.js failed: No such file or directory
        Router Configuration recommended pre-reqs status:
        [✔] Swapfile=1048572 kB
        [✔] DNS Filter=ON
        [✔] DNS Filter=ROUTER
        [✔] WAN: Use local caching DNS server as system resolver=NO
        [✔] Enable local NTP server=YES
        [✔] Enable DNS Rebind protection=NO
        [✔] Enable DNSSEC support=NO
        Options:
        [✔] unbound Logging
        [✔] unbound CPU/Memory Performance tweaks
        [✔] Router GUI statistics TAB installed
unbound (pid 11424) is running... uptime: 0 Days, 00:02:41 version: 1.9.6 # rgnldo Github Version=v1.06 Martineau update (Date Loaded by unbound_manager Sun Mar 1 12:40:08 MEZ 2020)
3  = Advanced Tools
e  = Exit Script
E:Option ==>
I asked because have experienced problems with unboung starting after reboot with alpha build. When downgrade to 384.15 stable biuld No problems at all.
Many thanks to all involved [emoji4]
3  = Advanced Tools
e  = Exit Script
E:Option ==> s
Strange...
Yes, unbound should start automatically after a REBOOT;
What errors prevented unbound from starting?
3  = Advanced Tools
e  = Exit Script
E:Option ==> sgui
y
        [✔] DNS Filter=ON
        Options:
        [✔] unbound Logging
3  = Advanced Tools
e  = Exit Script
E:Option ==>
Unfortunately there is a typo in @juched's script, the intended copy command 'cp' is incorrect
if [ ! -f "/tmp/menuTree.js" ]; then
       p -f "/www/require/modules/menuTree.js" "/tmp/"
fi
I suggest you use amtm to install one of the scripts that also supports the addons TAB, then retry the 'sgui' command.
Thanks, I installed uiDivStats and uiScribe, but the "Addons" button does not reappear... *sad*
Run
uiDivStats startup
I've just hotfixed the reason why it didn't appear after install....my bad
I wanted to install uiDivStats, but this happend:
 Enter option  j5
_____________________________________________
 This installs uiDivStats - WebUI for Diversion statistics
 on your router.
 Author: Jack Yaz
 https://www.snbforums.com/threads/uidivstats-webui-for-diversion-statistics.56393/
 Continue? [1=Yes e=Exit] 1
uiDivStats: Welcome to uiDivStats v1.3.1, a script by JackYaz
uiDivStats: Checking your router meets the requirements for uiDivStats
Downloading http://bin.entware.net/armv7sf-k2.6/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Package grep (3.3-1) installed in root is up to date.
/jffs/scripts/uiDivStats: line 1256: can't open /jffs/addons/uiDivStats.d/uidivstats_www.asp: no such file
uiDivStats: New version of uidivstats_www.asp downloaded
uiDivStats: Mounting uiDivStats WebUI page as user2.asp
uiDivStats: Starting Diversion statistic generation...
But thanks! The Addons button is back again! :-)
The Addons button is back again! :)
Does unbound_manager 'sgui' command now correctly add the unbound statistics GUI TAB?
I am running RT-AC86U 384.16_alpha1-ga40d2d5f30 and when developing/testing unbound_manager, I regularly need to REBOOT, and unbound always starts automatically.
What errors are you experiencing that is seemingly causing '/opt/etc/init.d/S61unbound' to fail to start unbound?
 Enter option  j5
 on your router.
 Author: Jack Yaz
But thanks! The Addons button is back again! :)
Please post this on the appropriate thread now, thanks!
EDIT: also hotfixed
What can I say?
Brilliant. Thanks to all involved for all their hard work. Unbound has been working flawlessly for ages and now with the bonus of the GUI.
Thank you all.
NEW: Add commandline option to restart unbound i.e. 'unbound_manager restart'
@juched unbound_manager will retrieve the GUI TAB files from your Github, so you no longer need to tediously create unnecessary external Pull-requests.
If you agree, I will modify unbound_manager to also retrieve the Ad Block files from your repository?
Thanks, I guess this changes how I use git now :)
I am ok with the same for ad block, but the current change on my repo moves sites/permlist/blockhost to /opt/share/unbound/configs so they need to be downloaded the first time, and then not touched after so people do not loose their settings.
RT-AX88U 384.16 Alpha 1 updated to Unbound Manager v2.14 and 'sgui'. Everything works great. Even reboots on the Alpha 1.
Thank you to all involved! @Martineau, @juched, @Jack Yaz and all the silent contributors and of course, to all the testers to make this happen. :)
This just keeps getting better and better.
Not for me. I get the following
"unbound NOT installed! or 'extended-stats:' template NOT defined in 'unbound.conf'?
