Martineau
Part of the Furniture
Apologies.Unable to get 3.10 beta from dev branch
It flashes and return to menu with minor update for 3.09
Kernol
Please post your ? command and s command when you get a chance - mine is below
PS since I use Diversion I am not using adblock
Code:A:Option ==> ? Version=3.09 Local md5=f99c48a3a5e7393490b6b21919b62a1a Github md5=f99c48a3a5e7393490b6b21919b62a1a /jffs/addons/unbound/unbound_manager.md5 md5=f99c48a3a5e7393490b6b21919b62a1a Router Configuration recommended pre-reqs status: [✔] Swapfile=2097148 kB [✔] DNS Filter=ON [✔] DNS Filter=ROUTER [✔] WAN: Use local caching DNS server as system resolver=NO [✔] Entware NTP server is running [✔] Enable DNS Rebind protection=NO [✔] Enable DNSSEC support=NO [✖] Warning Skynet's Country BAN feature is currently ACTIVE and may significantly reduce unbound performance and in some cases block sites Options: Auto Reply='y' for User Selectable Options ('1 4 5') unbound Logging,Performance Tweaks,Firefox DoH [✔] unbound Logging [✔] unbound CPU/Memory Performance tweaks [✔] Firefox DNS-over-HTTPS (DoH) DISABLE/Blocker [✔] Router Graphical GUI statistics TAB installed [✔] unbound-control FAST response ENABLED [✔] DNS Firewall ENABLED unbound Memory/Cache: 'key-cache-size:' 8388608 (8.00 MB) 'msg-cache-size:' 8388608 (8.00 MB) 6% used 555365 (542.35 KB) 'rrset-cache-size:' 16777216 (16.00 MB) 10% used 1775426 (1.69 MB) System Memory/Cache: total used free shared buffers cached Mem: 515184 425944 89240 0 3004 32912 -/+ buffers/cache: 390028 125156 Swap: 2097148 77412 2019736
Code:A:Option ==> s total.num.queries=33102 total.num.expired=1775 total.requestlist.exceeded=0 total.tcpusage=0 total.num.queries_ip_ratelimited=0 total.num.recursivereplies=2101 total.requestlist.current.all=0 msg.cache.count=2921 total.num.cachehits=31001 total.requestlist.avg=1.03428 total.requestlist.current.user=0 rrset.cache.count=8567 total.num.cachemiss=2101 total.requestlist.max=51 total.recursion.time.avg=0.322397 infra.cache.count=2618 total.num.prefetch=2392 total.requestlist.overwritten=0 total.recursion.time.median=0.208716 key.cache.count=487 Summary: Cache Hits success=93.00%
Version=3.09
[✔] DNS Filter=ON
[✔] Enable local NTP server=YES
Options: Auto Reply='y' for User Selectable Options ('4') Performance Tweaks
'msg-cache-size:' 8388608 (8.00 MB) 1% used 155473 (151.83 KB)
'rrset-cache-size:' 16777216 (16.00 MB) 2% used 491235 (479.72 KB)
Mem: 255676 116748 138928 0 2008 19820
-/+ buffers/cache: 94920 160756
Swap: 2097148 0 2097148
total.num.queries=1136 total.requestlist.avg=1.04955 total.recursion.time.median=0.752877
total.num.queries_ip_ratelimited=0 total.requestlist.max=16 total.tcpusage=0
total.num.cachehits=476 total.requestlist.overwritten=0 msg.cache.count=834
total.num.cachemiss=660 total.requestlist.exceeded=0 rrset.cache.count=2458
total.num.prefetch=349 total.requestlist.current.all=0 infra.cache.count=844
total.num.expired=335 total.requestlist.current.user=0 key.cache.count=97
total.num.recursivereplies=660 total.recursion.time.avg=1.017393
Summary: Cache Hits success=41.00%
For my recent two threads configuration, after 12 hours the requests seem to be split pretty much 50-50 between themI updated to 3.10 beta. now it explains low hit rate for multiple threads - as it is showing average in 3.09 when using multiple threads.
after restart and do some browsing one thread has 15 % second 11 % - stats are showing 13 %
A:Option ==> s
total.num.queries=31212 total.num.expired=2934 total.requestlist.exceeded=0 total.tcpusage=0
total.num.queries_ip_ratelimited=0 total.num.recursivereplies=3878 total.requestlist.current.all=0 msg.cache.count=3413
total.num.cachehits=27334 total.requestlist.avg=1.39012 total.requestlist.current.user=0 rrset.cache.count=9005
total.num.cachemiss=3878 total.requestlist.max=26 total.recursion.time.avg=0.117486 infra.cache.count=2969
total.num.prefetch=3730 total.requestlist.overwritten=0 total.recursion.time.median=0.0555293 key.cache.count=453
Summary: Cache Hits success=87.00%
thread0.num.queries=15489 thread0.num.expired=1536 thread0.requestlist.exceeded=0 thread0.tcpusage=0
thread0.num.queries_ip_ratelimited=0 thread0.num.recursivereplies=1887 thread0.requestlist.current.all=0 msg.cache.count=3413
thread0.num.cachehits=13602 thread0.requestlist.avg=1.42722 thread0.requestlist.current.user=0 rrset.cache.count=9005
thread0.num.cachemiss=1887 thread0.requestlist.max=26 thread0.recursion.time.avg=0.114474 infra.cache.count=2969
thread0.num.prefetch=1919 thread0.requestlist.overwritten=0 thread0.recursion.time.median=0.0541181 key.cache.count=453
Thread 0: Cache Hits success=87.00%
thread1.num.queries=15723 thread1.num.expired=1398 thread1.requestlist.exceeded=0 thread1.tcpusage=0
thread1.num.queries_ip_ratelimited=0 thread1.num.recursivereplies=1991 thread1.requestlist.current.all=0 msg.cache.count=3413
thread1.num.cachehits=13732 thread1.requestlist.avg=1.35297 thread1.requestlist.current.user=0 rrset.cache.count=9005
thread1.num.cachemiss=1991 thread1.requestlist.max=25 thread1.recursion.time.avg=0.120342 infra.cache.count=2969
thread1.num.prefetch=1811 thread1.requestlist.overwritten=0 thread1.recursion.time.median=0.0569405 key.cache.count=453
Thread 1: Cache Hits success=87.00%
e = Exit Script [?]
A:Option ==> s
thread0.num.queries=121 thread0.num.expired=1 thread0.requestlist.exceeded=0 thread0.tcpusage=0
thread0.num.queries_ip_ratelimited=0 thread0.num.recursivereplies=46 thread0.requestlist.current.all=0 msg.cache.count=953
thread0.num.cachehits=75 thread0.requestlist.avg=1.4898 thread0.requestlist.current.user=0 rrset.cache.count=5219
thread0.num.cachemiss=46 thread0.requestlist.max=6 thread0.recursion.time.avg=0.127746 infra.cache.count=149
thread0.num.prefetch=3 thread0.requestlist.overwritten=0 thread0.recursion.time.median=0.0538331 key.cache.count=48
Thread 0 Summary: Cache Hits success=61.00%
thread1.num.queries=127 thread1.num.expired=0 thread1.requestlist.exceeded=0 thread1.tcpusage=0
thread1.num.queries_ip_ratelimited=0 thread1.num.recursivereplies=55 thread1.requestlist.current.all=0 msg.cache.count=953
thread1.num.cachehits=72 thread1.requestlist.avg=1.67273 thread1.requestlist.current.user=0 rrset.cache.count=5219
thread1.num.cachemiss=55 thread1.requestlist.max=19 thread1.recursion.time.avg=0.149601 infra.cache.count=149
thread1.num.prefetch=0 thread1.requestlist.overwritten=0 thread1.recursion.time.median=0.0959634 key.cache.count=48
Thread 1 Summary: Cache Hits success=56.00%
thread2.num.queries=78 thread2.num.expired=0 thread2.requestlist.exceeded=0 thread2.tcpusage=0
thread2.num.queries_ip_ratelimited=0 thread2.num.recursivereplies=49 thread2.requestlist.current.all=0 msg.cache.count=953
thread2.num.cachehits=29 thread2.requestlist.avg=1.59184 thread2.requestlist.current.user=0 rrset.cache.count=5219
thread2.num.cachemiss=49 thread2.requestlist.max=8 thread2.recursion.time.avg=0.109549 infra.cache.count=149
thread2.num.prefetch=0 thread2.requestlist.overwritten=0 thread2.recursion.time.median=0.0643657 key.cache.count=48
Thread 2 Summary: Cache Hits success=37.00%
It is rare for me to advertise the use of the GitHub 'dev' branch, but in the rush (because it was getting late here) I lazily didn't alter the version number for this particular temporary/experimental feature, but I have now corrected this oversight earlier today.@Martineau, would you consider adding 'Beta' or whatever indication you deem appropriate to the versions downloaded from the 'dev' branch?
That is what I already proposed in post 1884#As for the screen real estate ,just a suggestion to have 's' show the individual threads only, since you already have 's thread' that show the additional information.
As requested ...
EDIT: I am intrigued by the fact that my dump of the config above does not - like yours - show that Logging is enabled - but it most certainly is - can see it in scribe and in the unbound webui stats ???Code:Version=3.09 Local md5=f99c48a3a5e7393490b6b21919b62a1a Github md5=f99c48a3a5e7393490b6b21919b62a1a /jffs/addons/unbound/unbound_manager.md5 md5=f99c48a3a5e7393490b6b21919b62a1a Router Configuration recommended pre-reqs status: [✔] Swapfile=2097148 kB [✔] DNS Filter=ON [✔] DNS Filter=ROUTER [✔] WAN: Use local caching DNS server as system resolver=NO [✔] Enable local NTP server=YES [✔] Enable DNS Rebind protection=NO [✔] Enable DNSSEC support=NO Options: Auto Reply='y' for User Selectable Options ('4') Performance Tweaks [✔] unbound CPU/Memory Performance tweaks [✔] Router Graphical GUI statistics TAB installed [✔] unbound-control FAST response ENABLED unbound Memory/Cache: 'key-cache-size:' 8388608 (8.00 MB) 'msg-cache-size:' 8388608 (8.00 MB) 1% used 155473 (151.83 KB) 'rrset-cache-size:' 16777216 (16.00 MB) 2% used 491235 (479.72 KB) System Memory/Cache: total used free shared buffers cached Mem: 255676 116748 138928 0 2008 19820 -/+ buffers/cache: 94920 160756 Swap: 2097148 0 2097148
and "s" ...
Code:total.num.queries=1136 total.requestlist.avg=1.04955 total.recursion.time.median=0.752877 total.num.queries_ip_ratelimited=0 total.requestlist.max=16 total.tcpusage=0 total.num.cachehits=476 total.requestlist.overwritten=0 msg.cache.count=834 total.num.cachemiss=660 total.requestlist.exceeded=0 rrset.cache.count=2458 total.num.prefetch=349 total.requestlist.current.all=0 infra.cache.count=844 total.num.expired=335 total.requestlist.current.user=0 key.cache.count=97 total.num.recursivereplies=660 total.recursion.time.avg=1.017393 Summary: Cache Hits success=41.00%
Thanks - have yet to try fresh install with command line - which I assume you got from here ...
https://github.com/MartineauUK/Unbo...-the-commandline-the-default-is-advanced-mode
Thanks,Hi Martineau
I substituted made up values below for WAN Gateway address -
gives following outputCode:ip route | grep ppp0
Code:110.3.231.6 dev ppp0 proto kernel scope link default via 110.3.231.6 dev ppp0
Your total.num.queries=1136 - thats a very very small sample - hardly a basis for calculating final cache stats - get that figure up to somewhere approaching 30000++ then you can make a case for low cache success rate of 40%
A:Option ==> s
thread0.num.queries=3361 thread0.num.expired=1314 thread0.requestlist.exceeded=0 thread0.tcpusage=0
thread0.num.queries_ip_ratelimited=0 thread0.num.recursivereplies=941 thread0.requestlist.current.all=0 msg.cache.count=7364
thread0.num.cachehits=2420 thread0.requestlist.avg=0.63709 thread0.requestlist.current.user=0 rrset.cache.count=7248
thread0.num.cachemiss=941 thread0.requestlist.max=31 thread0.recursion.time.avg=0.346957 infra.cache.count=3051
thread0.num.prefetch=1561 thread0.requestlist.overwritten=0 thread0.recursion.time.median=0.104239 key.cache.count=497
Thread 0 Summary: Cache Hits success=72.00%
thread1.num.queries=3314 thread1.num.expired=1297 thread1.requestlist.exceeded=0 thread1.tcpusage=0
thread1.num.queries_ip_ratelimited=0 thread1.num.recursivereplies=946 thread1.requestlist.current.all=0 msg.cache.count=7364
thread1.num.cachehits=2368 thread1.requestlist.avg=0.787607 thread1.requestlist.current.user=0 rrset.cache.count=7248
thread1.num.cachemiss=946 thread1.requestlist.max=38 thread1.recursion.time.avg=0.320597 infra.cache.count=3051
thread1.num.prefetch=1507 thread1.requestlist.overwritten=0 thread1.recursion.time.median=0.0971741 key.cache.count=497
Thread 1 Summary: Cache Hits success=71.00%
unbound (pid 11696 11499) is running... uptime: 0 Days, 14:38:39 version: 1.10.0 # rgnldo Github Version=v1.09 Martineau update (Date Loaded by unbound_manager Fri May 1 20:07:14 DST 2020)
# no threads and no memory slabs for threads
num-threads: 2
msg-cache-slabs: 1
rrset-cache-slabs: 1
infra-cache-slabs: 1
key-cache-slabs: 1
# tiny memory cache / # prefetch / # gentle on recursion
extended-statistics: yes # v1.06 Martineau for @juched GUI TAB
cache-min-ttl: 300
outgoing-range: 450
num-queries-per-thread: 256
edns-buffer-size: 1232
max-udp-size: 1232
harden-algo-downgrade: yes
harden-referral-path: yes
harden-large-queries: yes
harden-short-bufsize: yes
identity: "DNS"
use-caps-for-id: yes
hide-identity: yes
hide-version: yes
do-not-query-localhost: no
aggressive-nsec: yes
ratelimit: 1000
prefetch: yes
prefetch-key: yes
serve-expired: yes
serve-expired-ttl: 3600
deny-any: yes
'key-cache-size:' 4194304 (4.00 MB)
'msg-cache-size:' 4194304 (4.00 MB) 27% used 1164354 (1.11 MB)
'rrset-cache-size:' 4194304 (4.00 MB) 28% used 1190198 (1.14 MB)
No doubt you are diligently measuring the effects of your tweaks? and it is your prerogative to decide on the settings appropriate for your environment.Not bad at all. Looks cleaner indeed Martineau. I will be leaving num-threads to 2 but i will go to unbound defaults which are 4mb per thread. This means each thread will have 4mb for each cache.Code:A:Option ==> s thread0.num.queries=3361 thread0.num.expired=1314 thread0.requestlist.exceeded=0 thread0.tcpusage=0 thread0.num.queries_ip_ratelimited=0 thread0.num.recursivereplies=941 thread0.requestlist.current.all=0 msg.cache.count=7364 thread0.num.cachehits=2420 thread0.requestlist.avg=0.63709 thread0.requestlist.current.user=0 rrset.cache.count=7248 thread0.num.cachemiss=941 thread0.requestlist.max=31 thread0.recursion.time.avg=0.346957 infra.cache.count=3051 thread0.num.prefetch=1561 thread0.requestlist.overwritten=0 thread0.recursion.time.median=0.104239 key.cache.count=497 Thread 0 Summary: Cache Hits success=72.00% thread1.num.queries=3314 thread1.num.expired=1297 thread1.requestlist.exceeded=0 thread1.tcpusage=0 thread1.num.queries_ip_ratelimited=0 thread1.num.recursivereplies=946 thread1.requestlist.current.all=0 msg.cache.count=7364 thread1.num.cachehits=2368 thread1.requestlist.avg=0.787607 thread1.requestlist.current.user=0 rrset.cache.count=7248 thread1.num.cachemiss=946 thread1.requestlist.max=38 thread1.recursion.time.avg=0.320597 infra.cache.count=3051 thread1.num.prefetch=1507 thread1.requestlist.overwritten=0 thread1.recursion.time.median=0.0971741 key.cache.count=497 Thread 1 Summary: Cache Hits success=71.00% unbound (pid 11696 11499) is running... uptime: 0 Days, 14:38:39 version: 1.10.0 # rgnldo Github Version=v1.09 Martineau update (Date Loaded by unbound_manager Fri May 1 20:07:14 DST 2020)
Code:# no threads and no memory slabs for threads num-threads: 2 msg-cache-slabs: 1 rrset-cache-slabs: 1 infra-cache-slabs: 1 key-cache-slabs: 1 # tiny memory cache / # prefetch / # gentle on recursion extended-statistics: yes # v1.06 Martineau for @juched GUI TAB cache-min-ttl: 300 outgoing-range: 450 num-queries-per-thread: 256 edns-buffer-size: 1232 max-udp-size: 1232 harden-algo-downgrade: yes harden-referral-path: yes harden-large-queries: yes harden-short-bufsize: yes identity: "DNS" use-caps-for-id: yes hide-identity: yes hide-version: yes do-not-query-localhost: no aggressive-nsec: yes ratelimit: 1000 prefetch: yes prefetch-key: yes serve-expired: yes serve-expired-ttl: 3600 deny-any: yes
Code:unbound Memory/Cache: 'key-cache-size:' 4194304 (4.00 MB) 'msg-cache-size:' 4194304 (4.00 MB) 27% used 1164354 (1.11 MB) 'rrset-cache-size:' 4194304 (4.00 MB) 28% used 1190198 (1.14 MB)
Set *-slabs to a power of 2 close to the num-threads value.
Do this for msg-cache-slabs, rrset-cache-slabs, infra-cache-slabs and key-cache-slabs. This reduces lock contention.
Increase the memory size of the cache.
Use roughly twice as much rrset cache memory as you use msg cache memory.
I see your point but i'm going by the optimised forked operation:No doubt you are diligently measuring the effects of your tweaks? and it is your prerogative to decide on the settings appropriate for your environment.
However, I'm not saying that the vendor's notes were written with routers in mind, but two of your choices seemingly contradict their published Optimise recommendations (although I haven't recently waded thru' the User Group posts to see if their advice has changed with respect to routers)
i.e.
Code:Set *-slabs to a power of 2 close to the num-threads value. Do this for msg-cache-slabs, rrset-cache-slabs, infra-cache-slabs and key-cache-slabs. This reduces lock contention. Increase the memory size of the cache. Use roughly twice as much rrset cache memory as you use msg cache memory.
Forked operation
Unbound has a unique mode where it can operate without threading. This can be useful if libevent fails on the platform, for extra performance, or for creating walls between the cores so that one cannot poison another.
To compile for forked operation, before compilation use ./configure --without-pthreads --without-solaris-threads to disable threads and enable forked operation. Because no locking has to be done, the code speeds up (about 10 to 20%).
In the config file, num-threads still specifies the number of cores you want to use (even though it uses processes and not threads). And note that the outgoing-range and cache memory values are all per thread. This means that much more memory is used, as every core uses its own cache. Because every core has its own cache, if one gets cache poisoned, the others are not affected.
# with forked operation
server:
# use all CPUs
num-threads: <number of cores>
msg-cache-slabs: 1
key-cache-slabs: 1
# more cache memory, rrset=msg*2
# total usage is 150m*cores
rrset-cache-size: 100m
msg-cache-size: 50m
# does not depend on number of cores
outgoing-range: 950
num-queries-per-thread: 512
# Larger socket buffer. OS may need config.
so-rcvbuf: 4m
Because every process is using at most 1024 file descriptors now, the effective maximum is the number of cores * 1024. The config above uses 950 per process, for 4 processes gives a respectable 3800 sockets. The number of queries per thread is half the number of sockets, to guarantee that every query can get a socket, and some to spare for queries-for-nameservers.
Using forked operation together with libevent is also possible. It may be useful to force the OS to service the filedescriptors for different processes, instead of threads. This may have (radically) different performance if the underlying network stack uses (slow) lookup structures per-process.
the entware unbound is compiled for threading isn't it?I see your point but i'm going by the optimised forked operation:
Also, last time i had unbound running for almost 1 month my cache never reached 4mb with single thread. My configuration at the time was exactly as the forked version and my cache rate was well over 90%.Code:Forked operation Unbound has a unique mode where it can operate without threading. This can be useful if libevent fails on the platform, for extra performance, or for creating walls between the cores so that one cannot poison another. To compile for forked operation, before compilation use ./configure --without-pthreads --without-solaris-threads to disable threads and enable forked operation. Because no locking has to be done, the code speeds up (about 10 to 20%). In the config file, num-threads still specifies the number of cores you want to use (even though it uses processes and not threads). And note that the outgoing-range and cache memory values are all per thread. This means that much more memory is used, as every core uses its own cache. Because every core has its own cache, if one gets cache poisoned, the others are not affected. # with forked operation server: # use all CPUs num-threads: <number of cores> msg-cache-slabs: 1 rrset-cache-slabs: 1 infra-cache-slabs: 1 key-cache-slabs: 1 # more cache memory, rrset=msg*2 # total usage is 150m*cores rrset-cache-size: 100m msg-cache-size: 50m # does not depend on number of cores outgoing-range: 950 num-queries-per-thread: 512 # Larger socket buffer. OS may need config. so-rcvbuf: 4m Because every process is using at most 1024 file descriptors now, the effective maximum is the number of cores * 1024. The config above uses 950 per process, for 4 processes gives a respectable 3800 sockets. The number of queries per thread is half the number of sockets, to guarantee that every query can get a socket, and some to spare for queries-for-nameservers. Using forked operation together with libevent is also possible. It may be useful to force the OS to service the filedescriptors for different processes, instead of threads. This may have (radically) different performance if the underlying network stack uses (slow) lookup structures per-process.
--without-pthreads --without-solaris-threads --without-libevent
Ah unbound -VCode:--without-pthreads --without-solaris-threads --without-libevent
total.num.queries=909569 total.requestlist.exceeded=0
total.num.queries_ip_ratelimited=0 total.requestlist.current.all=0
total.num.cachehits=907772 total.requestlist.current.user=0
total.num.cachemiss=1797 total.recursion.time.avg=0.216086
total.num.prefetch=835 total.recursion.time.median=0.165271
total.num.expired=805 total.tcpusage=0
total.num.recursivereplies=1797 msg.cache.count=3231
total.requestlist.avg=1.03837 rrset.cache.count=9068
total.requestlist.max=18 infra.cache.count=2689
total.requestlist.overwritten=0 key.cache.count=557
Summary: Cache Hits success=99.00%
Wish I had thought of that - nice easy quick fixMy cash hit rate is low. I need to visit an ATM.![]()
Hopefully the stimulus check from the IRS should help out with your low cash rate.My cash hit rate is low. I need to visit an ATM.![]()
Welcome To SNBForums
