Interesting observation using Alpha 2 on an AC88U.
I don't recall seeing this Bad eraseblock message in older firmwares:
Jul 31 20:00:18 kernel: Northstar brcmnand NAND Flash Controller driver, Version
Jul 31 20:00:18 kernel: NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unkno
Jul 31 20:00:18 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Jul 31 20:00:18 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24
Jul 31 20:00:18 kernel: Available 7 bytes at (off,len):
Jul 31 20:00:18 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Jul 31 20:00:18 kernel: Scanning device for bad blocks
Jul 31 20:00:18 kernel: Bad eraseblock 220 at 0x000001b80000
Jul 31 20:00:18 kernel: Bad eraseblock 233 at 0x000001d20000
Jul 31 20:00:18 kernel: Bad eraseblock 690 at 0x000005640000
Jul 31 20:00:18 kernel: Bad eraseblock 989 at 0x000007ba0000
Jul 31 20:00:18 kernel: Options: NO_AUTOINCR,NO_READRDY,
Jul 31 20:00:18 kernel: Creating 1 MTD partitions on "brcmnand":
Jul 31 20:00:18 kernel: 0x000004000000-0x000008000000 : "brcmnand"
Does the new Broadcom SDK have a new NAND driver? Or, is my NAND having problems?
Hello, im also having same issue after flashing alpha2 on my new RT-AC88U, i still can send it back to vendor to get a new one unit... should i?
Aug  1 02:00:15 kernel: Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
Aug  1 02:00:15 kernel: NAND device: Manufacturer ID: 0xc8, Chip ID: 0xd1 (Unknown NAND 128MiB 3,3V 8-bit)
Aug  1 02:00:15 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug  1 02:00:15 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug  1 02:00:15 kernel: Available 7 bytes at (off,len):
Aug  1 02:00:15 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug  1 02:00:15 kernel: Scanning device for bad blocks
Aug  1 02:00:15 kernel: Bad eraseblock 763 at 0x000005f60000
Aug  1 02:00:15 kernel: Options: NO_AUTOINCR,NO_READRDY,
Aug  1 02:00:15 kernel: Creating 1 MTD partitions on "brcmnand":
Aug  1 02:00:15 kernel: 0x000004000000-0x000008000000 : "brcmnand"
