MilkywayChris
So my setup is:
- router: RT-AX88U with firmware 386.2_4 (have tried updating it some weeks ago, but the webinterface didn't do anything when I selected the firmware file, will try later when son is not gaming)
- node before: RT-AC68U with firmware 386.2_4
- node now: RT-AX68U with firmware 386.4
Nodes are connected via cable.
The issue I'm having is that the wireless network stops working after a few days.
Quite random: can work OK for a whole week, can fail after 1 or 2 days.
When I turn off the node, there are no stability issues.
But then I don't have enough bandwidth in my desk for video conferencing which is quite essential these days.
In the spring I want to start up the RT-AC68U in the garden for coverage there.
I've tried these things:
- disable Roaming Assistant on both bands. Seemed to have helped somewhat.
- disable Wi-Fi Agile Multiband
- reboot every day at 5 am. Helped a little bit, but no guarantee.
- no guest networks are active, no VPNs, no addons are running, nothing special.
This has been an issue since I turned on AiMesh.
I had hoped it would be resolved with the new node, but no such luck and it's driving me nuts.
Any suggestions?
Any suggestions?
