USB 3.0 disk is not mounted after reboot
Santer
I have my rt-ac68u with the latest merlin build (376.45) and working Transcend 500Gb HDD connected to USB 3.0 port. Everything is ok until reboot (it looks like disconnected in web). In order to make it work I have to phisically disconnect HDD, reboot a router and then connect HDD again. How can I avoid these uncomfortable steps?
What does the HDD diagnostics say?
I have had this problem a few times, most of the times were due to the partition was not unmounted correctly and OPTWARE complaining. A file scan solved it, I didn't need to physically unplug and plug it.
So, HDD scan didn't say anything bad. The problem still happens. BTW, it's NTFS HDD, does it matter?
