TexasDave
I want to use Cloudflare for my DDNS. I believe I need to use a ddns-start script - Yes?
If I have two domains at Cloudflare, do I just copy the script twice into one file and run the same script code twice but subsituting the proper ZONE_ID, RECORD_NAME, RECORD_TTL,API_TOKEN for each domain?
Or is there a better way? I see there are some other script files out there as well. Any of these used widely or prefered to the above? And can I register my IP twice in the same script?
Thank you!
Thank you!
