Using RT-N66U as Local DNS server
There are two files (inside the zip):
Move nat-start into "/jffs/scripts". Move hosts.add in "/jffs/configs". Then do "chmod a+rx /jffs/scripts/*". Reboot.
Of course take a look at the files and adjust them to your needs. You can use notepad++ for that.
I've tried the two files (0755), reboot the router, but when I input in browser "http://transmission or http://asus.transmission" nothing happens: "the page can not be displayed". What I'm doing wrong? Shouldn't redirect me to: http://routerip:9091/transmission/web?
Thank you!
In telnet type "vi /etc/hosts". You should see at the end of the file the lines you wrote in "hosts.add". Exit by typing ":q".
If the lines are there, there must be a problem with the iptables. We'll try to solve it.
Also, didn't you edit the files with windows notepad, did you?
Yes, the files are displayed at running the command.
I edited host.add and nat files on the router with WinSCP.
Try to navigate to 192.168.0.253 in your web browser. If it doesn't point you to 192.168.1.1:9091 there must be a problem with the iptables. You could then try sinshiva's method: just copy paste from his post.
It doesn't point me to 192.168.1.1:9091. I will try later the sinshiva's method.
That's strange, however. I've now checked my files and they are exactly the same. I've rebooted and it still works fine. :confused:
Are you browsing to "http://asus.transmission" or to "www.asus.transmission"? I've just noticed that the latter doesn't work. Probably needs a specific rule in etc/hosts. Edit: I meant in /jffs/configs/hosts.add
I'm browsing "http://asus.transmission".
Sorry for bumping such a old thread. But this is the closest I have found to what I would like to do also. But I cant get it to work. Are there maybe things that have changed in later versions of the firmware? I'm running Asuswrt-Merlin 380.58.
The only thing that works is the hosts.add things. But that don't help much =\
