ekhoo
I've amended the previous network setup and now for the guest network, we're using a separate router/WAN link & provider.
I've attached the network diagram. Basically the WAP321 access points have two SSIDs, each mapped to VLAN 1 and 2 where 2 is for guests. Both routers also run DHCP.
If I connect to the guest network, I get a 192.168.24.x IP. Connecting to the internal network, I get a 192.168.101.x IP. On the 101 network, everything works. I can ping the gateway or router. On the guest network, I can get an IP address but I cannot ping the gateway or the switch (.24.254 and .24.222).
However, if I connect a cable to the LAN port of the router, I'm able to ping from the 24 network the switch as well as the router (24.222). I believe the problem has to do with the VLAN and routing on the SG300 but I can't seem to figure out how to solve this. Any ideas?
