GK59
st3v3n, you know I do like the idea of the conversion and would be up for it but I've also been buying inexpensive routers for years now and willing to go upwards but again that TM-AC1900 does sound interesting for sure. I'll surely look at both that and the RTAC-66_B1 but the 1.8Ghz cpu on the RT-AC86U is so tempting for me, though it is at my predetermined budget, decisions decisions. Worth noting tho, we do a lot of streaming here, our area is about 1500 sq ft coverage so the memory would be a key issue and cpu and is why I also like your RT-AC3200 since our complex has many units with boatload of wireless clients, do you find that that 3rd band helps or is just good insurance? This will aid in my decision which is boiling down now to your AC3200 and the AC86U.
Edit: After some thought I may give that RTAC-66_B1 a shot before I move to a higher model to see how it goes with our current configuration, does this one have dual core as well as the TM-AC1900?. The one thing that's really bothering me atm is I use ExpressVPN, and I use their VPN configuration at the router level in the VPN Client tab. Here's the thing with that, my download speeds are complete crap, around 5 or so Mbps on speedtest.net. If I turn off the router level, i.e. "service state" off, they go back to normal (no VPN), they also are about normal with just ExpressVPN's web app(Windows app) on so I'm not sure what to make of this, perhaps my settings in the VPN client? They appear to be normal as is explained in the setup, hope you might help shed some light on this and I'm certainly more than curious as to how the new router may help with this, if any.
Edit2: I just got out of a chat with ExpressVPN and from the sound of what the rep was describing, it may be the limitations of an N-based router hardware and the processing on a single cpu core, which sounds like it could be but as much as 60 Mbps?? but again I'll try a new router and see what happens.
