When my VPN goes down and vpnmon-r2 v2.58 Executing VPN Reset the kill switch does NOT work. this can be duplicate by running “kill $(ops | grep [v]pnclient1 | awk '{print $1}')” I can see my IP from my ISP in my conky and ip chicken before the VPN is connected.
Asus RT-AC3100 Merlin 386.11
log from one time the VPN was down
thinks
Thu May 25 11:15:43 DST 2023 - VPNMON-R2 ----------> WARNING: Average PING of 196.941 ms across VPN tunnel 1 > 100 m>
Thu May 25 11:15:43 DST 2023 - VPNMON-R2 - Executing VPN Reset
Thu May 25 11:15:48 DST 2023 - VPNMON-R2 - Killed all VPN Client Connections
Thu May 25 11:16:11 DST 2023 - VPNMON-R2 - VPN1 Client ON - Lowest PING of 1 VPN slots
Thu May 25 11:16:15 DST 2023 - VPNMON-R2 - VPN Reset Finished
Thu May 25 11:16:18 DST 2023 - VPNMON-R2 - Resuming normal operations
Thu May 25 11:16:31 DST 2023 - VPNMON-R2 - API call made to update WAN0 city to xxx
Thu May 25 11:16:32 DST 2023 - VPNMON-R2 - API call made to update VPN city to xxxx
Thu May 25 11:21:20 DST 2023 - VPNMON-R2 - API call made to update WAN0 city to xxx
Thu May 25 11:21:22 DST 2023 - VPNMON-R2 - API call made to update VPN city to xxxx
Thu May 25 11:23:47 DST 2023 - VPNMON-R2 ----------> ERROR: VPN1 Ping/HTTP response failed
Thu May 25 11:23:48 DST 2023 - VPNMON-R2 ----------> ERROR: VPN1 Connection failed - Executing VPN Reset
Thu May 25 11:23:48 DST 2023 - VPNMON-R2 - Executing VPN Reset
Thu May 25 11:23:53 DST 2023 - VPNMON-R2 - Killed all VPN Client Connections
Thu May 25 11:24:06 DST 2023 - VPNMON-R2 - VPN1 Client ON - Lowest PING of 1 VPN slots
Thu May 25 11:24:10 DST 2023 - VPNMON-R2 - VPN Reset Finished
Thu May 25 11:24:13 DST 2023 - VPNMON-R2 - Resuming normal operations
Thu May 25 11:24:26 DST 2023 - VPNMON-R2 - API call made to update WAN0 city to xxx
Thu May 25 11:24:27 DST 2023 - VPNMON-R2 ----------> ERROR: VPN1 Connection failed - Executing VPN Reset
Thu May 25 11:24:27 DST 2023 - VPNMON-R2 - Executing VPN Reset
Thu May 25 11:24:31 DST 2023 - VPNMON-R2 - Killed all VPN Client Connections
Thu May 25 11:24:44 DST 2023 - VPNMON-R2 - VPN1 Client ON - Lowest PING of 1 VPN slots
Thu May 25 11:24:48 DST 2023 - VPNMON-R2 - VPN Reset Finished
Thu May 25 11:24:51 DST 2023 - VPNMON-R2 - Resuming normal operations
thinks
