WAN IP Issue on RT-AC66U
SuperMckee
I am unable to keep my ip address on the WAN port. I had it plugged into the cable modem directly and it wouldn't renew the address. I added another router in between and assigned a static address on the wan connection. It lost the connection again (all info still there, just no connectivity). I just hit apply on the page with the IP and the connection was restored.
Heres the timeline in the logs from broken to working
Nov 5 15:17:12 WAN(0) Connection: Detected that the WAN Connection Type was PPPoE. But the PPPoE Setting was not complete.
Nov 5 15:17:12 stop_nat_rules: apply the redirect_rules!
Nov 5 15:17:18 dnsmasq[5631]: exiting on receipt of SIGTERM
Nov 5 15:17:18 dnsmasq[11759]: started, version 2.72test3 cachesize 1500
Nov 5 15:17:18 dnsmasq[11759]: warning: interface ppp1* does not currently exist
Nov 5 15:17:18 dnsmasq[11759]: asynchronous logging enabled, queue limit is 5 messages
Nov 5 15:17:18 dnsmasq-dhcp[11759]: DHCP, IP range 192.168.0.1 -- 192.168.0.254, lease time 1d
Nov 5 15:17:18 dnsmasq[11759]: using local addresses only for domain home.local
Nov 5 15:17:18 dnsmasq[11759]: read /etc/hosts - 5 addresses
Nov 5 15:17:18 dnsmasq[11759]: read /etc/hosts.dnsmasq - 7 addresses
Nov 5 15:17:18 dnsmasq-dhcp[11759]: read /etc/ethers - 7 addresses
Nov 5 15:17:18 dnsmasq[11759]: using nameserver 192.168.1.45#53
Nov 5 15:30:54 dnsmasq-dhcp[11759]: DHCPREQUEST(br0) 192.168.0.113 e0:cb:4e:98:f5:06
Nov 5 15:30:54 dnsmasq-dhcp[11759]: DHCPACK(br0) 192.168.0.113 e0:cb:4e:98:f5:06 Office10
Nov 5 15:33:36 rc_service: httpd 341:notify_rc restart_wan_if 0
Nov 5 15:33:36 dnsmasq[11759]: read /etc/hosts - 5 addresses
Nov 5 15:33:36 dnsmasq[11759]: read /etc/hosts.dnsmasq - 7 addresses
Nov 5 15:33:36 dnsmasq-dhcp[11759]: read /etc/ethers - 7 addresses
Nov 5 15:33:36 kernel: Attempt to kill tasklet from interrupt
Nov 5 15:33:36 kernel: br0: port 1(vlan1) entering disabled state
Nov 5 15:33:36 kernel: br0: port 1(vlan1) entering listening state
Nov 5 15:33:36 dnsmasq[11759]: using local addresses only for domain home.local
Nov 5 15:33:36 dnsmasq[11759]: using nameserver 192.168.1.45#53
Nov 5 15:33:36 miniupnpd[4486]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Nov 5 15:33:36 miniupnpd[4486]: Failed to get IP for interface eth0
Nov 5 15:33:36 miniupnpd[4486]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Nov 5 15:33:36 kernel: br0: port 1(vlan1) entering learning state
Nov 5 15:33:36 kernel: br0: topology change detected, propagating
Nov 5 15:33:36 kernel: br0: port 1(vlan1) entering forwarding state
Nov 5 15:33:38 dnsmasq[11759]: read /etc/hosts - 5 addresses
Nov 5 15:33:38 dnsmasq[11759]: read /etc/hosts.dnsmasq - 7 addresses
Nov 5 15:33:38 dnsmasq-dhcp[11759]: read /etc/ethers - 7 addresses
Nov 5 15:33:38 dnsmasq[11759]: using local addresses only for domain home.local
Nov 5 15:33:38 dnsmasq[11759]: using nameserver 192.168.1.45#53
Nov 5 15:33:38 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Nov 5 15:33:38 dnsmasq[11759]: exiting on receipt of SIGTERM
Nov 5 15:33:38 dnsmasq[12002]: started, version 2.72test3 cachesize 1500
Nov 5 15:33:38 dnsmasq[12002]: warning: interface ppp1* does not currently exist
Nov 5 15:33:38 dnsmasq[12002]: asynchronous logging enabled, queue limit is 5 messages
Nov 5 15:33:38 dnsmasq-dhcp[12002]: DHCP, IP range 192.168.0.1 -- 192.168.0.254, lease time 1d
Nov 5 15:33:38 dnsmasq[12002]: using local addresses only for domain home.local
Nov 5 15:33:38 dnsmasq[12002]: read /etc/hosts - 5 addresses
Nov 5 15:33:38 dnsmasq[12002]: read /etc/hosts.dnsmasq - 7 addresses
Nov 5 15:33:38 dnsmasq-dhcp[12002]: read /etc/ethers - 7 addresses
Nov 5 15:33:39 dnsmasq[12002]: using local addresses only for domain home.local
Nov 5 15:33:39 dnsmasq[12002]: using nameserver 192.168.1.45#53
Nov 5 15:33:39 miniupnpd[4486]: shutting down MiniUPnPd
Nov 5 15:33:39 miniupnpd[12032]: HTTP listening on port 50133
Nov 5 15:33:39 miniupnpd[12032]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 5 15:33:42 WAN(0) Connection: WAN was restored.
