Jan 24 00:00:32 disk_monitor: Got SIGALRM...
another day, booting:
Jan 24 10:44:51 rc_service: httpd 429:notify_rc reboot
Jan 24 10:44:51 kernel: Attempt to kill tasklet from interrupt
Jan 24 10:44:52 iTunes: daemon is stoped
Jan 24 10:44:52 FTP Server: daemon is stoped
Jan 24 10:44:52 Samba Server: smb daemon is stoped
Jan 24 10:44:52 kernel: gro disabled
Jan 24 10:44:53 Timemachine: daemon is stoped
Jan 24 10:44:53 WEBDAV Server: daemon is stoped
Jan 24 10:44:53 NAT Tunnel: AAE Service is stopped
Jan 24 10:44:53 kernel: Stop the IPS/AppID engine...
Jan 24 10:44:54 WEBDAV Server: daemon is stoped
Jan 24 10:44:54 NAT Tunnel: AAE Service is stopped
Jan 24 10:44:54 iTunes: daemon is stoped
Jan 24 10:44:54 FTP Server: daemon is stoped
Jan 24 10:44:54 Samba Server: smb daemon is stoped
Jan 24 10:44:54 kernel: gro disabled
Jan 24 10:44:54 Timemachine: daemon is stoped
Jan 24 10:44:54 disk_monitor: Finish
Jan 24 10:44:55 NAT Tunnel: AAE Service is stopped
Jan 24 10:44:55 wanduck exit: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jan 24 10:44:56 kernel: klogd: exiting
Jan 24 10:44:56 syslogd exiting
Aug 1 03:00:10 syslogd started: BusyBox v1.17.4
Aug 1 03:00:10 kernel: klogd started: BusyBox v1.17.4 (2015-12-22 15:07:06 CST)
Aug 1 03:00:10 kernel: Linux version 2.6.36.4brcmarm (raymonddev@raymonddev-1404) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Tue Dec 22 15:13:08 CST 2015
Aug 1 03:00:10 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug 1 03:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug 1 03:00:10 kernel: Machine: Northstar Prototype
Aug 1 03:00:10 kernel: Ignoring unrecognised tag 0x00000000
Aug 1 03:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug 1 03:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60416
Aug 1 03:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug 1 03:00:10 kernel: Memory: 255516k/255516k available, 6628k reserved, 0K highmem
Aug 1 03:00:10 kernel: Virtual kernel memory layout:
Aug 1 03:00:10 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Aug 1 03:00:10 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Aug 1 03:00:10 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Aug 1 03:00:10 kernel: vmalloc : 0xd0800000 - 0xf0000000 ( 504 MB)
Aug 1 03:00:10 kernel: lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
Aug 1 03:00:10 kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Aug 1 03:00:10 kernel: .init : 0xc0008000 - 0xc003d000 ( 212 kB)
Aug 1 03:00:10 kernel: .text : 0xc003d000 - 0xc03a3000 (3480 kB)
Aug 1 03:00:10 kernel: .data : 0xc03ba000 - 0xc03dcfe0 ( 140 kB)
Aug 1 03:00:10 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Aug 1 03:00:10 kernel: Mount-cache hash table entries: 512
Aug 1 03:00:10 kernel: CPU1: Booted secondary processor
Aug 1 03:00:10 kernel: Found a AMD NAND flash:
Aug 1 03:00:10 kernel: Total size: 128MB
Aug 1 03:00:10 kernel: Block size: 128KB
Aug 1 03:00:10 kernel: Page Size: 2048B
Aug 1 03:00:10 kernel: OOB Size: 64B
Aug 1 03:00:10 kernel: Sector size: 512B
Aug 1 03:00:10 kernel: Spare size: 16B
Aug 1 03:00:10 kernel: ECC level: 8 (8-bit)
Aug 1 03:00:10 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Aug 1 03:00:10 kernel: bio: create slab <bio-0> at 0
Aug 1 03:00:10 kernel: PCI: no core
Aug 1 03:00:11 kernel: PCI: Fixing up bus 0
Aug 1 03:00:11 kernel: PCI: Fixing up bus 1
Aug 1 03:00:11 kernel: VFS: Disk quotas dquot_6.5.2
Aug 1 03:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug 1 03:00:11 stop_nat_rules: apply the redirect_rules!
Aug 1 03:00:11 qcsapi: write qcsapi conf ok
Aug 1 03:00:11 kernel: pflash: found no supported devices
Aug 1 03:00:11 kernel: bcmsflash: found no supported devices
Aug 1 03:00:11 kernel: Boot partition size = 524288(0x80000)
Aug 1 03:00:11 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Aug 1 03:00:11 kernel: nflash: squash filesystem with lzma found at block 28
Aug 1 03:00:11 kernel: Creating 4 MTD partitions on "nflash":
Aug 1 03:00:11 kernel: 0x000000000000-0x000000080000 : "boot"
Aug 1 03:00:11 kernel: 0x000000080000-0x000000200000 : "nvram"
Aug 1 03:00:11 WAN Connection: ISP's DHCP did not function properly.
Aug 1 03:00:11 kernel: 0x000000200000-0x000004000000 : "linux"
Aug 1 03:00:11 kernel: 0x000000399f90-0x000004000000 : "rootfs"
Aug 1 03:00:11 kernel: Registering the dns_resolver key type
Aug 1 03:00:11 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug 1 03:00:11 kernel: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug 1 03:00:11 kernel: Available 7 bytes at (off,len):
Aug 1 03:00:11 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug 1 03:00:11 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Aug 1 03:00:11 kernel: Creating 2 MTD partitions on "brcmnand":
Aug 1 03:00:11 kernel: 0x000004000000-0x000007ec0000 : "brcmnand"
Aug 1 03:00:11 kernel: 0x000007ec0000-0x000008000000 : "asus"
Aug 1 03:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Aug 1 03:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 03:00:11 kernel: Disabling lock debugging due to kernel taint
Aug 1 03:00:11 kernel: et_module_init: passivemode set to 0x0
Aug 1 03:00:11 kernel: et_module_init: txworkq set to 0x1
Aug 1 03:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 03:00:11 kernel: =================
Aug 1 03:00:11 kernel: robo chk regs:
Aug 1 03:00:11 kernel: ===================
Aug 1 03:00:11 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Aug 1 03:00:11 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Aug 1 03:00:11 kernel: (0x00,0x0e)Port 8 States Override: 0x0a
Aug 1 03:00:11 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x00
Aug 1 03:00:11 kernel: (0x02,0x00) Global Management Config: 0x00
Aug 1 03:00:11 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x00
Aug 1 03:00:11 kernel: (0x02,0x03) BRCM HDR Control Register: 0x00
Aug 1 03:00:11 kernel: (0x00,0x0b) Switch Mode Register: 0x06
Aug 1 03:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.105 (r485445)
Aug 1 03:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug 1 03:00:11 kernel: wl_module_init: igs set to 0x0
Aug 1 03:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug 1 03:00:11 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.105 (r485445)
Aug 1 03:00:24 dnsmasq[423]: warning: interface ppp1* does not currently exist
Aug 1 03:00:24 RT-AC87U: start httpd
Aug 1 03:00:24 hour monitor: daemon is starting
Aug 1 03:00:25 disk monitor: be idle
Aug 1 03:00:25 wan: [wan0_hwaddr] == [08:xx:xx:xx:xx:Xx]
Aug 1 03:00:25 syslog: Generating SSL certificate...
Aug 1 03:00:25 kernel: SCSI subsystem initialized
Aug 1 03:00:26 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug 1 03:00:27 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Aug 1 03:00:27 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Aug 1 03:00:27 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Aug 1 03:00:27 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug 1 03:00:27 kernel: nf_nat_rtsp v0.6.21 loading
Aug 1 03:00:27 wan: finish adding multi routes
Aug 1 03:00:28 rc_service: udhcpc 530:notify_rc stop_upnp
Aug 1 03:00:28 rc_service: udhcpc 530:notify_rc start_upnp
Aug 1 03:00:28 rc_service: waitting "stop_upnp" via udhcpc ...
Aug 1 03:00:29 ntp: start NTP update
Jan 24 10:47:01 rc_service: ntp 470:notify_rc restart_upnp
Jan 24 10:47:02 rc_service: ntp 470:notify_rc restart_diskmon
Jan 24 10:47:02 disk_monitor: Finish
Jan 24 10:47:02 WAN Connection: WAN was restored.
Jan 24 10:47:04 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Jan 24 10:47:05 disk monitor: be idle
Jan 24 10:47:05 kernel: sizeof forward param = 160
Jan 24 10:47:07 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jan 24 10:47:10 dhcp client: bound 178.xx.xxx.xxx via 178.xx.xxx.x during 18000 seconds.
Jan 24 10:47:25 qtn: bootcfg.tgz exists
Jan 24 10:47:31 dfs: start dfs scan
Jan 24 10:47:31 nodfs_scan: complete
Jan 24 10:47:32 crond[431]: time disparity of 253967 minutes detected
