WAN Terminated Issue with Merlin 378.55
Dear Merlin, the same issue was happened again in this morning, is still the ISP isue? thanks in adavanced.
Nov 27 04:36:50 miniupnpd[601]: upnp_event_process_notify: connect(192.168.254.11:2869): Connection timed out
Nov 27 05:10:44 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.6 28:5a:eb:eb:9f:d1
Nov 27 05:10:44 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.6 28:5a:eb:eb:9f:d1 ZhangWQ-iPhone
Nov 27 05:13:53 miniupnpd[601]: upnp_event_process_notify: connect(192.168.254.11:2869): Connection timed out
Nov 27 05:25:34 dropbear[21854]: Child connection from 158.69.192.138:43525
Nov 27 05:25:36 dropbear[21854]: Login attempt for nonexistent user from 158.69.192.138:43525
Nov 27 05:25:36 dropbear[21854]: Exit before auth: Disconnect received
Nov 27 05:31:51 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.11 4c:34:88:a0:49:ed
Nov 27 05:31:51 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.11 4c:34:88:a0:49:ed ZhangWQ-T450
Nov 27 05:33:11 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.11 4c:34:88:a0:49:ed
Nov 27 05:33:11 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.11 4c:34:88:a0:49:ed ZhangWQ-T450
Nov 27 05:33:58 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.11 4c:34:88:a0:49:ed
Nov 27 05:33:58 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.11 4c:34:88:a0:49:ed ZhangWQ-T450
Nov 27 05:34:50 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.11 4c:34:88:a0:49:ed
Nov 27 05:34:50 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.11 4c:34:88:a0:49:ed ZhangWQ-T450
Nov 27 05:35:47 dropbear[21898]: Child connection from 123.151.42.61:48728
Nov 27 05:35:47 dropbear[21898]: Exit before auth: Exited normally
Nov 27 05:56:57 pptpd[21987]: CTRL: Client 123.151.149.222 control connection started
Nov 27 05:56:57 pptpd[21987]: CTRL: EOF or bad error reading ctrl packet length.
Nov 27 05:56:57 pptpd[21987]: CTRL: couldn't read packet header (exit)
Nov 27 05:56:57 pptpd[21987]: CTRL: CTRL read failed
Nov 27 05:56:57 pptpd[21987]: CTRL: Client 123.151.149.222 control connection finished
Nov 27 06:10:21 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca
Nov 27 06:10:21 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca Mi-Box
Nov 27 06:21:00 pppd[386]: No response to 10 echo-requests
Nov 27 06:21:00 pppd[386]: Serial link appears to be disconnected.
Nov 27 06:21:00 pppd[386]: Connect time 4038.9 minutes.
Nov 27 06:21:00 pppd[386]: Sent 1279368747 bytes, received 1015344270 bytes.
Nov 27 06:21:01 dnsmasq[278]: read /etc/hosts - 5 addresses
Nov 27 06:21:01 dnsmasq[278]: read /etc/hosts.dnsmasq - 9 addresses
Nov 27 06:21:01 dnsmasq-dhcp[278]: read /etc/ethers - 9 addresses
Nov 27 06:21:01 dnsmasq[278]: using nameserver 202.106.195.68#53 for domain local
Nov 27 06:21:01 dnsmasq[278]: using nameserver 202.106.46.151#53 for domain local
Nov 27 06:21:01 miniupnpd[601]: Failed to get IP for interface ppp0
Nov 27 06:21:01 miniupnpd[601]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Nov 27 06:21:03 WAN Connection: Fail to connect with some issues.
Nov 27 06:21:03 stop_nat_rules: apply the redirect_rules!
Nov 27 06:21:07 pppd[386]: Connection terminated.
Nov 27 06:21:07 pppd[386]: Sent PADT
Nov 27 06:21:07 pppd[386]: Modem hangup
Nov 27 06:31:52 pppd[386]: Timeout waiting for PADO packets
Nov 27 06:32:22 miniupnpd[601]: Failed to get IP for interface ppp0
Nov 27 06:32:22 miniupnpd[601]: Failed to get ip address for interface ppp0
Nov 27 06:33:07 pppd[386]: Timeout waiting for PADO packets
Nov 27 06:40:42 pppd[386]: PPP session is 31094 (0x7976)
Nov 27 06:40:42 pppd[386]: Connected to d8:49:0b:b6:8c:d2 via interface eth0
Nov 27 06:40:42 pppd[386]: Using interface ppp0
Nov 27 06:40:42 pppd[386]: Connect: ppp0 <--> eth0
Nov 27 06:40:47 pppd[386]: Remote message: Authentication success,Welcome!
Nov 27 06:40:47 pppd[386]: PAP authentication succeeded
Nov 27 06:40:47 pppd[386]: peer from calling number D8:49:0B:B6:8C:D2 authorized
Nov 27 06:40:47 miniupnpd[601]: Failed to get IP for interface ppp0
Nov 27 06:40:47 miniupnpd[601]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Nov 27 06:40:47 pppd[386]: local IP address 114.250.221.249
Nov 27 06:40:47 pppd[386]: remote IP address 114.250.216.1
Nov 27 06:40:47 pppd[386]: primary DNS address 202.106.46.151
Nov 27 06:40:47 pppd[386]: secondary DNS address 202.106.195.68
Nov 27 06:40:47 miniupnpd[601]: ioctl(s, SIOCGIFADDR, ...): Cannot assign requested address
Nov 27 06:40:47 rc_service: ip-up 22214:notify_rc start_firewall
Nov 27 06:40:47 dnsmasq[278]: read /etc/hosts - 5 addresses
Nov 27 06:40:47 dnsmasq[278]: read /etc/hosts.dnsmasq - 9 addresses
Nov 27 06:40:47 dnsmasq-dhcp[278]: read /etc/ethers - 9 addresses
Nov 27 06:40:47 dnsmasq[278]: using nameserver 202.106.195.68#53 for domain local
Nov 27 06:40:47 dnsmasq[278]: using nameserver 202.106.46.151#53 for domain local
Nov 27 06:40:47 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 27 06:40:47 wan: finish adding multi routes
Nov 27 06:40:47 rc_service: ip-up 22214:notify_rc stop_upnp
Nov 27 06:40:47 miniupnpd[601]: shutting down MiniUPnPd
Nov 27 06:40:48 rc_service: ip-up 22214:notify_rc start_upnp
Nov 27 06:40:48 miniupnpd[22249]: HTTP listening on port 57007
Nov 27 06:40:48 miniupnpd[22249]: Listening for NAT-PMP/PCP traffic on port 5351
Nov 27 06:40:49 WAN Connection: WAN was restored.
Nov 27 06:40:49 ddns update: ez-ipupdate: starting...
Nov 27 06:40:49 ddns update: connected to nwsrv-ns1.asus.com (103.10.4.108) on port 80.
Nov 27 06:40:50 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Thu, 26 Nov 2015 22:40:49 GMT^M Server: Apache^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Nov 27 06:40:50 ddns update: retval= 0, ddns_return_code (,200)
Nov 27 06:40:50 ddns update: asusddns_update: 0
Nov 27 06:40:50 ddns: ddns update ok
Nov 27 06:40:50 rc_service: ip-up 22214:notify_rc stop_pptpd
Nov 27 06:40:50 rc_service: ip-up 22214:notify_rc start_pptpd
Nov 27 06:40:50 pptpd[22254]: MGR: Config file not found!
Nov 27 06:40:50 pptpd[22254]: MGR: Maximum of 100 connections reduced to 10, not enough IP addresses given
Nov 27 06:40:50 pptpd[22254]: accel-pptpd-0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Nov 27 06:40:50 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Nov 27 06:40:50 bcrelay[22257]: Running as child
Nov 27 06:40:50 pptpd[22256]: MGR: Manager process started
Nov 27 06:40:50 pptpd[22256]: MGR: Maximum of 10 connections available
Nov 27 06:41:20 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca
Nov 27 06:41:20 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca Mi-Box
Nov 27 06:43:11 pppd[386]: No response to 10 echo-requests
Nov 27 06:43:11 pppd[386]: Serial link appears to be disconnected.
Nov 27 06:43:11 pppd[386]: Connect time 2.4 minutes.
Nov 27 06:43:11 pppd[386]: Sent 448104 bytes, received 6783654 bytes.
Nov 27 06:43:11 miniupnpd[22249]: Failed to get IP for interface ppp0
Nov 27 06:43:11 miniupnpd[22249]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Nov 27 06:43:11 dnsmasq[278]: read /etc/hosts - 5 addresses
Nov 27 06:43:11 dnsmasq[278]: read /etc/hosts.dnsmasq - 9 addresses
Nov 27 06:43:11 dnsmasq-dhcp[278]: read /etc/ethers - 9 addresses
Nov 27 06:43:11 dnsmasq[278]: using nameserver 202.106.195.68#53 for domain local
Nov 27 06:43:11 dnsmasq[278]: using nameserver 202.106.46.151#53 for domain local
Nov 27 06:43:14 WAN Connection: Fail to connect with some issues.
Nov 27 06:43:14 stop_nat_rules: apply the redirect_rules!
Nov 27 06:43:17 pppd[386]: Connection terminated.
Nov 27 06:43:17 pppd[386]: Sent PADT
Nov 27 06:43:17 pppd[386]: Modem hangup
Nov 27 06:44:02 pppd[386]: Timeout waiting for PADO packets
Nov 27 06:50:04 dnsmasq-dhcp[278]: DHCPREQUEST(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca
Nov 27 06:50:04 dnsmasq-dhcp[278]: DHCPACK(br0) 192.168.254.4 6c:fa:a7:4b:b2:ca Mi-Box
Nov 27 06:50:17 pppd[386]: Timeout waiting for PADO packets
Nov 27 06:54:17 miniupnpd[22249]: Failed to get ip address for interface ppp0
Nov 27 06:55:17 pppd[386]: Timeout waiting for PADO packets
Nov 27 06:55:56 miniupnpd[22249]: Failed to get ip address for interface ppp0
