WANFailover What advantages does this script offer over existing features?
MarcoPolo
Hello,
Sorry for this probably silly question, but what advantages does this script offer over existing features?
It makes the built-in WAN failover functionality actually work, and gives you a lot more control. 👍
The most common issue with built-in dual WAN in Asuswrt is unreliable fail back/over up to the point it requires physical disconnection of Ethernet cables to WAN ports. Some folks report it works better with Ethernet + USB compared to Ethernet + Ethernet. Some folks report it works well for their use case and with their specific equipment. Perhaps the issue is hardware compatibility related as well.
I solved this problem with these commands:
cru a restart_wan1 “0 */6 * * * service ‘restart_wan_if 1’”
service “restart_wan_if 1”
in file /jffs/scripts/services-start.
(for the configuration shown in the screenshot in the 1st post)
The aim is to set the state to 2 for all Wan interfaces (which can be checked with this command):
nvram show | grep wan[0,1,2,3,4]_state_t
I don't know if what I've done represents a problem, but in any case the native failover works without a hitch with this.
(AX88U / 3004.388.8_4)
The aim is to set the state to 2 for all Wan interfaces with this command:
Try nvram show | grep wan | grep _state_t as a single command to view state for all WAN interfaces.
