Jack-Sparr0w
Top 10 Cyber Attack Maps to See Digital Threats 2024
Best Cyber Attack Maps - 1. Kaspersky Cyber Attack Map 2.Norse Attack Map 3. Arbor Networks 4.Digital Attack Map 5.Trend Micro Botnet Map
Why don't you use DOS protection with the large list? I have an RT-AX88UDepends on your router, just don't use firewall does protection.
This is my country block list:I use the same one without dos protection in a 66u b1, by the way thank you for the country block list is there any more countries that would be good to add to list.
sh /jffs/scripts/firewall ban country "ae af az ba bg br cn cu cz eg ee ge hr hu id in il ir iq it kp kz kw kg lv md nl om pk qa ro rs ru sa sk si sy tr tw ua uz va"
Your CPU will spike and the script might not work at 1 ICMP per second, Ping of Death : Only allow one ICMP packet(type 8) to pass per second or drop the length of ICMP packet over 65535. You range will show zero after a couple bad boots on skynet. Your ISP or VPN will be better for dealing with dos. Its really ment for hosting server or website. VPN would be best bet for that problem.Why don't you use DOS protection with the large list? I have an RT-AX88U
ru cn kp ir sa pk ae ng in af dz by bf bi cf td co cd cg cu eg sv er ht hn iq ke lb ly gn ml mr mx mm ne ph so ss sd th to ua ve ye zw br np ro az ba bg cz ee ge hr hu id il it kz kw kg lv md nl om qa rs sk si sy tr tw uz va,ae af az ba bg br cn cu cz eg ee ge hr hu id in il ir iq it kp kz kw kg lv md nl om pk qa ro rs ru sa sk si sy tr tw ua uz va
Italy is part of 14 eyes, could have trouble if you block it https://securitymadesimple.org/cybersecurity-blog/fourteen-eyes-surveillance-explained/This is my country block list:
Code:sh /jffs/scripts/firewall ban country "ae af az ba bg br cn cu cz eg ee ge hr hu id in il ir iq it kp kz kw kg lv md nl om pk qa ro rs ru sa sk si sy tr tw ua uz va"
@Viktor Jaep Which one of the umteen lists mentioned in this thread are you referring to as "the large one"?!?The large one works great... no complaints either way.
@Viktor Jaep Which one of the umteen lists mentioned in this thread are you referring to as "the large one"?!?![]()
I don't see why I can't block whole IP blocks of countries I don't want traffic coming or going to... if they're 14eyes or not. Not seeing how that could give me trouble.Italy is part of 14 eyes, could have trouble if you block it https://securitymadesimple.org/cybersecurity-blog/fourteen-eyes-surveillance-explained/
I don't see why I can't block whole IP blocks of countries I don't want traffic coming or going to... if they're 14eyes or not. Not seeing how that could give me trouble. Nord VPN dos not work well if you block GB or NL. I guess cause im using Nord I have been using that as rule of thumb.
Ayee!!, but this is truely the biggest one...I'm calling in the Guiness Book of World Records on this one @SomeWhereOverTheRainBow...![]()
Crazy... I don't remember saying half of these things. Must have had one too many to drink last night!
I'm also a 100% Nord user, BTW.
Thread starter | Title | Forum | Replies | Date |
S | Skynet Skynet - Block all as default, allow by exception | Asuswrt-Merlin AddOns | 3 | |
A | Skynet Outbound block notification mail | Asuswrt-Merlin AddOns | 0 |
Welcome To SNBForums
