Skynet What are some good current block lists? - Skynet
Curious if there's a way to whitelist TOR exit nodes only via outbound connections (assume he wants to connect to TOR) and then only allow established connections back through inbound with IPtables. This would eliminate other users on TOR from being allowed to hit your WAN IP with a hammer due to them being whitelisted.
I will mention again a source of more lists than you can 'shake a stick at' !!!
(Usable by Skynet & Diversion etc)
filterlists.com
Please ensure you select the list(s) in the right format or convert/edit as needed. :)
filterlists.com
You're correct, that site does have a large collection of lists; However, I still would caution users to research what lists they choose off of there specifically block.
100% agree.
Block lists etc are not a random game.
As always understand what they do, where they have been derived from and what you gain & lose by using them.
Ayee!!, but this is truely the biggest one...
which is a combination of that entire filter list all aggregated, so there is a better use of ranges!
When I try to import this list I get a 404 error. Can someone please explain what I am doing wrong?
I am using @Viktor Jaep URL but excluding one troublesome list within called firehol_level3.
customlisturl="https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list"
excludelists="firehol_level3.netset"
If you have that list Viktor Jaep, I will be forever in your debt
I am not following what trouble you are having. Here is my understanding:
Input Custom Filter List URL:
[URL]: https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
[$] /jffs/scripts/firewall banmalware https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
[i] Excluding Lists Matching The Words; firehol_level3.netset
[i] Custom Filter Detected: https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
[i] Downloading filter.list         | [0s]
[i] Refreshing Whitelists           | [5s]
[i] Consolidating Blacklist         | [22s]
[i] Filtering IPv4 Addresses        | [3s]
[i] Filtering IPv4 Ranges           | [1s]
[i] Applying New Blacklist          | [5s]
[i] Refreshing AiProtect Bans       | [1s]
[i] Saving Changes                  | [1s]
[i] For Whitelisting Assistance -
[i] https://www.snbforums.com/threads/release-skynet-router-firewall-security-enhancements.16798/#post-115872
[#] 222469 IPs (+198958) -- 20309 Ranges Banned (+18629) || 10350 Inbound -- 336 Outbound Connections Blocked! [banmalware] [39s]
just need the old list, Building it off that . If you can give me that list I can make a list that blocks all nsa and cia and everything under the sun. I have and amazing accumulation of firewall lists. I really need the addresses in the old list first
This List Can Block CIA , terrorism, and Government
just shows ips, I need the filter list addresses
https://adaway.org/hosts.txt
https://big.oisd.nl/
https://bitbucket.org/ethanr/dns-blacklists/raw/8575c9f96e5b4a1308f2f12394abd86d0927a4a0/bad_lists/Mandiant_APT1_Report_Appendix_D.t
https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt
https://hostfiles.frogeye.fr/firstparty-trackers-hosts.txt
https://osint.digitalside.it/Threat-Intel/lists/latestdomains.txt
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext
https://phishing.army/download/phishing_army_blocklist_extended.txt
https://raw.githubusercontent.com/AssoEchap/stalkerware-indicators/master/generated/hosts
https://raw.githubusercontent.com/DandelionSprout/adfilt/master/Alternate%20versions%20Anti-Malware%20List/AntiMalwareHosts.txt
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/UncheckyAds/hosts
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.2o7Net/hosts
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Risk/hosts
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Spam/hosts
https://raw.githubusercontent.com/PolishFiltersTeam/KADhosts/master/KADhosts.txt
https://raw.githubusercontent.com/Spam404/lists/master/main-blacklist.txt
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
https://raw.githubusercontent.com/badmojr/1Hosts/refs/heads/master/Lite/domains.txt
https://raw.githubusercontent.com/bigdargon/hostsVN/master/hosts
https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt
https://raw.githubusercontent.com/d3ward/toolz/master/src/d3host.txt
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/domains/multi.txt
https://raw.githubusercontent.com/hagezi/dns-blocklists/main/domains/tif.txt
https://raw.githubusercontent.com/mitchellkrogza/Phishing.Database/master/phishing-domains-ACTIVE.txt
https://raw.githubusercontent.com/xRuffKez/NRD/refs/heads/main/lists/30-day_phishing/domains-only/nrd-phishing-30day.txt
https://urlhaus.abuse.ch/downloads/hostfile/
https://v.firebog.net/hosts/AdguardDNS.txt
https://v.firebog.net/hosts/Admiral.txt
https://v.firebog.net/hosts/Easylist.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://v.firebog.net/hosts/Prigent-Crypto.txt
https://v.firebog.net/hosts/RPiList-Malware.txt
https://v.firebog.net/hosts/RPiList-Phishing.txt
https://v.firebog.net/hosts/static/w3kbl.txt
https://zerodot1.gitlab.io/CoinBlockerLists/hosts_browser
