SomeWhereOverTheRainBow
Part of the Furniture
I would tell anyone, use either list to match your needs. If mine blocks too much, then use @Viktor Jaep . Both of our lists are pretty comprehensive. Let's be honest, they would be even better if skynet used an aggregation tool to shrink them down. But skynet does not aggregate ip addresses. Aggregation would be the next step improvement to skynets block-ability. This would reduce the memory footprint, and reduce the size of single IP lists incorporated. Aggregation would allow for more addresses to fall within the ranges whereby reducing skynets memory foot print on the router.Don't want to sound completely biased, but @SomeWhereOverTheRainBow's list is probably one of the best, with mine in a distant second. I built my own list and been using it for years, blocking the baddies from our family's network with minimal disruptions to blocked false positive content.
We even joined forces to build this filter validator to ensure the list you use doesn't have some gummed up content in there that could break Skynet:
https://www.snbforums.com/threads/f...l-filter-list-ipv4-integrity-validator.83876/
Here's the list URLs:
@SomeWhereOverTheRainBow: https://raw.githubusercontent.com/jumpsmm7/GeneratedAdblock/master/filter.list
My own flavor: https://raw.githubusercontent.com/ViktorJp/Skynet/main/filter.list
